17150 Discussions
Intel i5-2500 @3.30ghz very poor benchmark perfomance (1,60Ghz) - Help please!
JMigu
Hi people.
I am experiencing this problem with my processor.
After a fresh Windows 7 Ultima 64 installation it started to work really slow.
Ive made tests and the results were very bad (I let my benchmark results in the following images).
I also tested it on Ubuntu and the results were the following:
BenchmarksCPU BlowfishCPU BlowfishThis Machine1600 MHz3,016Intel(R) Celeron(R) M processor 1.50GHz(null)26.1876862PowerPC 740/750 (280.00MHz)(null)172.816713CPU CryptoHashCPU CryptoHashThis Machine1600 MHz610,282CPU FibonacciCPU FibonacciThis Machine1600 MHz1,423Intel(R) Celeron(R) M processor 1.50GHz(null)8.1375674PowerPC 740/750 (280.00MHz)(null)58.07682CPU N-QueensCPU N-QueensThis Machine1600 MHz4,032FPU FFTFPU FFTThis Machine1600 MHz0,849FPU RaytracingFPU RaytracingThis Machine1600 MHz5,791<...
Jose_H_Intel1
The information you provided does not look exactly normal; however, those benchmark tools are not validated by Intel®. The recommendation will be to reload BIOS settings to default, check the CPU temperature in BIOS and run the Intel® Processor Diagnostic Tool.
http://www.intel.com/support/processors/sb/CS-031726.htm Processors; What is the Intel� Processor Diagnostic Tool?
In case the issue persists you may provide further information like the IPDT result and your system configuration: motherboard model, memory part number or specifications, power supply, etc.
