Hi guys,
I have a recent problem where while gaming (Battlefield 1, Fallout 4, Heroes of the Storm), the screen will just freeze/lock up, mouse cursor does not move and there seems to be no keyboard input (for example pressing the numlock or capslock key doesnt light up).
Sometimes a BSOD will display saying "A clock interrupt was not received on a secondary processor within the allocated time interval". As far as I know, I havent really done anything to overclock my processor or whatever so I'm really confused as to why this is happening. Also, the processor, RAM, motherboard and GFX are recently bought, around 3 months ago and I fixed them up myself. I've looked into C:\Windows\Minidump and its empty as well.
Here are my computer specs:
Intel i5-6600K 3.50 ghz
Zotac GTX1060 Amp 6Gb
16Gb DDR4 2133mhz
Gigabyte GZ-Z170-D3H (rev 1.0) motherboard
Andyson Bronze 650W PSU
Windows 7 64-bit
Any help is greatly appreciated.
Cheers,
Zack
I ran Intel's Diagnostic Tool and this is the results if it helps
--- IPDT64 - Revision: 4.0.0.29
--- IPDT64 - Start Time: 22-Dec-16 4:25:45 PM
CPU1
Intel(R) spbc Module Test
Module Version: 1.0.8.64b.W
Start Time: Thu Dec 22 16:25:45 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
End Time: Thu Dec 22 16:25:45 2016
Total Time: seconds: 0
CPU1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
CPU1
CPU Brand String Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Floating Point Test
Module Version: 1.0.11.64b.W
AVX is supported in your OS
Max AVX supported = AVX2
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 23.595
Error: 0
--- Floating Point Test Passed!!!---
End Time: Thu Dec 22 16:25:47 2016
Total Time: seconds: 2
CPU1
Prime Number Generation Test
Module Version: 1.0.13.64b.W
Start Time: Thu Dec 22 16:25:47 2016
Test Result - PASS
Operation Per Second: 131377
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Thu Dec 22 16:25:49 2016
CPU1
Cache Test
Start Time: Thu Dec 22 16:25:49 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
FMA3 Test
Module Version: 1.0.10.64b.W
Test Result - PASS
--- CPU Features Detection ---
FMA3 - Supported --> Yes
FMA3 Test Result --- PASS
End Time: Thu Dec 22 16:25:55 2016
Total Time: seconds: 6
CPU1
AVX Test
Module Version: 2.0.8.64b.W
Start Time: Thu Dec 22 16:25:55 2016
Test Result - PASS
AVX - Supported --> Yes
AVX2 - Supported --> Yes
AVX512 - Supported --> No
AVX OS Support - Supported --> Yes
AES - Supported --> Yes
PCLMULQDQ - Supported --> Yes
AVX2 Test Result --- PASS
End Time: Thu Dec 22 16:26:01 2016
CPU1
IMC Test
Start Time: Thu Dec 22 16:26:01 2016
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
CPU1
PCH Test
Test Result - PASS
LPC deviceID = 0xa145
Chipset : Skylake Platform Controller Hub
No device connected to PCI Express Port 1
No device connected to PCI Express Port 5
No device connected to PCI Express Port 9
No device connected to PCI Express Port 1...
Hello idriszee,
In regard to your concern I would like to confirm some details:
Could you please confirm the model of the RAM that you are using?
Also, I would like to know the version of your BIOS?
As soon as you reply I will provide you further assistance.
Angie.
Hi Angie,
Thank you for your reply.
The RAM that I am using is Kingston 2x 8Gb PC4 2133 CL15 288 Pin UDIMM
BIOS Version is F5
Cheers,Zack
Hello idriszee,
I do apologize for the delay on my reply.
In regard to your concern, I was unable to find the graphics drivers of the manufacturer or OEM (Gigabyte as per your confirmation).
In the meantime, please try to install our generic graphic driver that might help you.
https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88345 Intel® Graphics Driver [15.45] (Version: 15.45.10.4542 (Latest) Date: 11/9/2016)
At this moment if the issue persists, my recommendation is to contact the support from Gigabyte, in order to confirm which will be the proper BIOS update that you must install.
Also, to confirm the compatibility of the RAM you are using.
http://www.gigabyte.com/support-downloads/support-downloads.aspx BIGABYTEhttp://www.gigabyte.com/support-downloads/support-downloads.aspx Technical Support Contact
I am looking forward to hearing from you.
Angie
Hello idriszee,
I would like to know if the information provided to you was able to solve your concern?
In case if you need further assistance do not hesitate to reply back.
Angie.
Hi Angie,
Thanks for getting back to me and apologies for my late reply.
I tried installing the Graphics Driver but it wasnt able to go through due to some incompatability.
I have cleaned the fans on my computer and this issue has not happened once, so i'm assuming that its a heat issue due to the amount of dust accumulated.
I think we can close this issue?
Thank you once again for your help!
Cheers,
Zack
Hello idriszee,
I am really glad to know that you were able to solve your concern.
If you need further assistance do not hesitate to use our forums:
/community/tech Intel Communities
Angie.
