- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi!
i have a MSI Tomahawk Z790 motherbard and my i7-14700 is getting very fast to 100°C, and i noticed on CPUID HWMonitor total package wats was 253W! (i thought max tdp is 220W)
I tested processor with Intel® Processor Diagnostic Tool and everything is ok., but temperatures are very high.
Idle temp. are about 40-45°C.
is this ok?
All settings in bios are default
Paweł
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I want to let you know that we do not provide undervolting controls/software/tools for locked non-K processors. Altering clock frequency or voltage may void any product warranties and reduce stability, security, performance, and life of the processor and other components. If options in BIOS are not available, contact your OEM or motherboard vendor. You may also visit this link for more details: Is It Possible to Undervolt a Locked Intel® Core™ Non-K Processor?
By the way , were you able to try the troubleshooting steps in the article I have sent in my previous post? If you have and the issue still persists, we can help you with the process of replacing the cpu fan. Let us know if the issue still exists after trying out the steps. I will be waiting for your reply
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
How are you doing? I am just checking in if the troubleshooting steps we recommended worked for you. Feel free to let us know if your encounter any issues so we can help you with the replacement of the fan. I will be waiting for your reply.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
A few days ago I bought a Deep Cool AK620 cooler, and today or tomorrow I will check whether it will cool properly, of course I will let you know.
Unfortunately, I don't have time for anything this week.
Pawel
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
Thank you for letting us know. Feel free to share the information here in this post. I will be waiting!
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
And I already know!
After changing the cooler (DeepCool AK620), temperatures are max. 85°C with Cinebench 23.
In normal operation (Blender) max. 75. So, the attached cooling has no chance with this processor.
Paweł
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I just want to make sure we are on the same page, from the temperature you mention, it is still within the allowable temperature allowed by the CPU, when you mentioned no chance, did you mean you are still experiencing the same issue with the CPU reaching to 100 degrees? I will be waiting for your reply.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
To sum up:
the cooling provided with the processor is definitely too weak, with each higher load the processor temperature was 99-100°C (in synthetic tests it was basically 100°C all the time), and the idle temperature was around 45-50°C .
With the new cooling (Deep Cool AK620), even with synthetic tests, the temperature is not higher than 86°C, and in the idle state it is about 36°C.
Additionally, with the new cooler, test results are approximately 10 percent higher. better than with box cooling.
Paweł
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
Thank you for sharing this information. I want to make sure we properly investigate this for you. As such, I will make sure to coordinate this information regarding the included fan on the i7-14700 and get back to you as soon as possible.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
ok,
Thank you
Paweł
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
Thank you for patiently waiting. Upon checking with our team, we can conclude that the original stock cooler is the source of the issue. We sincerely apologize for the inconvenience this has caused you. We will gladly process a replacement of this fan for you as long as the CPU markings are still within warranty. You may also visit 'Troubleshooting Fan Issues with Intel® Boxed Processors' as reference.
That being said, we highly recommend for you to request a replacement of this fan by submitting a support ticket.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
i can't create a support ticket, because don' have FPO (don' have the processor box, and I don't want to take off new cooler to write down the numbers.
Is there any other way to get FPO without this steps?
Paweł
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I understand your concern with the markings. The only way to gather the FPO and Serial Number without the CPU present is with the box that it came along with. Without this, it is necessary to gather this markings on the cpu itself. I sincerely apologize that I cannot provide another way but if you can locate the box of the CPU, you can include it in the support ticket that you will submit.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I am just checking in if you were able to gather the markings, we will keep being on the lookout for the new ticket that you will create. Thank you!
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello!
I haven't checked the numbers yet, I have too much work at the moment and I don't want to remove the cooling system, but I will probably do it soon, of course I will let you know.
And thank you for your interest in the matter.
Paweł
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
Thank you for letting us know. For now I will keep it open should you have further questions but you can also let me know if you want us to proceed in closing this one while we wait for you to submit a new ticket. I will be waiting for your reply.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I am just checking in on you. We will keep being on the lookout for the new ticket that you will create. Thank you!
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I understand that submitting a new ticket may take some time. To keep our records up-to-date, may I suggest we close the current ticket in the meantime? Please rest assured, you can always open a new one as needed. I will be waiting for your reply.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
How are you doing? I am just following up if you still need assistance in this thread. I will be waiting for your reply.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Pawel7,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Ramyer M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Disable CEP in bios people reccomend less heat same performance.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
