16770 ディスカッション
Intel i7 4510U not attaining max Turbo Boost Frequency
MChou4
ビギナー
9,083件の閲覧回数
I've just bought few days ago a new laptop http://shop.lenovo.com/us/en/laptops/lenovo/z-series/z50/# tab-tech_specs Lenovo Z50-70 with an Intel Core i7 4510U inside it. As well as in the description of the laptop, it is mentioned in http://ark.intel.com/products/81015/Intel-Core-i7-4510U-Processor-4M-Cache-up-to-3_10-GHz Intel's website that it has a 2.0Ghz base frequency, and a 3.1Ghz max Turbo Boost Frequency.
In the properties of my PC, which I upgraded to Windows 10 yesterday, it displays 2.6Ghz where most of my friends who have an i7 have their max Turbo Boost Frequency there.
But this doesn't correspond to the frequency I observe when I'm rendering a heavy 3D scene in Maya, because it attains 2.8 Ghz, but never 3.0Ghz or 3.1. I'm pretty sure that it has to because it is a very huge 3D scene.
Is Turbo Boost enabled?
If it's not how can I enable it?
8 返答(返信)
従業員
5,908件の閲覧回数
Me too Same problem
After upgrading to windows 10 my processor Max Core speed not the same as windows 7, in windows 10 Turbo-boost not working max speed in CPU stress test 2.6GHZ only
Intel® Core™ i7-3517U Processor (4M Cache, up to 3.00 GHz)
hbuch
ビギナー
5,908件の閲覧回数
also me (Core i5 750 on Gigabyte GA-P55-UD4)
rated: 2,67 GHz (multi 20)
Win7: 2,93-3,2 GHz (when under load on, somewhat fluctuating because of TDP/Temp, multi up to 24)
Win10: 2,8 GHz (permanently when at load, NEVER more, multi always 21)
* no load: correctly switches down to a multi of 9 with massively reduced voltage - for both Win7 and Win8
* Win8 must have turboboost enabled - but only 1 clockstep, not up to 4 like specified. was using all 4 clocksteps in Win7
従業員
5,908件の閲覧回数
If u found solution just post it don't forget and thanks
MChou4
ビギナー
5,908件の閲覧回数
Don't worry, I'm still experiencing the same problem.
Kevin_M_Intel
従業員
5,908件の閲覧回数
Hello All,
Please be aware that the Intel® Turbo Boost is enabled by default in all Intel® processor that support the feature and the only way to enable it or disable it is by accessing the BIOS. This option may not be available in the BIOS depending on the Computer Manufacture.
Here you can find more information about the technology:
https://www-ssl.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technology.html https://www-ssl.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technology.html
A processor running with Intel® Turbo Boost can increase the processor speed but it does not necessarily means that it will reach the Full speed because it depends upon a number or factors:
  • - Type of workload
  • - Number of active cores
  • - Estimated current consumption
  • - Estimated power consumption
  • - Processor temperature
Kevin M
hbuch
ビギナー
5,908件の閲覧回数
Hi Kevin,
has nothing to do with it. System was nicely using turboboost up to its maximum multi of 24 with Win7. After update to Win10, Turboboost is still used, but only up to multi of 21. Stock multi is 20 (i5 750).
Have changed nothing in BIOS after update. No overclock, using "optimized defaults". Even switched back to Win7 (on behalf of temporarily restoring Win7 image) and turboboost ran up to 24 like I always knew it. Back to Win10, I'm limited to 21, even for light singlethreaded integer code like eg. zipping or hashing.
Looks very much like a driver/CPU governor issue in Win10 to me.
Still annouying since it costs me 12% gaming performance (I'm CPU bound, did a quick bench). Overclocking is no solution since I had to disable Speedstep on this board which would make the CPU run always at 3++ GHz with 1,3V - and I need to be able to leave the machine running almost always without driving me poor for electricity.
Would be a good service from Intel to push MS to fixing such issues quickly!
hbuch
ビギナー
5,908件の閲覧回数
Win10 now uses all turboboost steps up to the max of x24
solution was to explicitly enable turboboost in BIOS. hat it set to the default of "auto" which worked beatifully in Win7, but Win10 needs it to explicitly set to enabled.
correction: it is the "C3/C6 states support" feature that modulates the maximum multiplier:
disabled: max multi=21 for both Win7 and Win10
enabled: max multi=24 for both Win7 and Win10
auto: max multi=24 for Win7 - but 21 for Win10 !!!
7
Ronny_G_Intel
モデレーター
5,908件の閲覧回数
Hi huch,
Thanks for the update, good to know.
返信
