16801 Discussions
Intel i7-6700k not active Turbo-Boost
RRamo9
Hey,
My intel i7-6700K processor does not activate the turbo-boost. It is installed in a temperature-controlled CPD and when the CPU is 100% does not activate the turbo-Boost and always has a clock speed of 4.0GHz. The operating system is Red Hat Enterprise Linux Server release 6.8. Why not activate the Turbo-Boost?
Thank you
Maybe bad cpu cooler. High temps ( not ideal ) can cause weird behavior. It is only hypothesis...
Hello rsf_89,
In regard to your concern, my recommendation is to confirm on the BIOS options, if the Intel® Turbo Boost Technology it is active.
If you are not able to see this option, if the issue persists or if you are not able to activate the Turbo Boost feature; please reply back with the model of your motherboard.
Hope I can hear from you soon.
Angie
Hello rsf_89,
I would like to confirm if you were able to confirm if the Intel® Turbo Boost Technology was active in your BIOS?
If the issue persists or if you are not able to activate the Turbo Boost feature; could you please reply back with the model of your motherboard?
I am looking forward to hearing from you.
Angie
Bad motherboard GIGABYTE Z170-D3H with faulty PCIE 3.0 and not boosting CPU ... never again...
Hello rsf_89,
I am really sorry for the inconvenience.
Do not hesitate if there is further assistance required.
Angie
RRamo9
The parameter Intel® Turbo Boost Technology are actived in BIOS.
El mother model is advantech model PCE-7129G2-00A1E ( http://downloadt.advantech.com/ProductFile/PIS/PCE-7129/Product%20-%20Datasheet/PCE-7129_DS(08.16.16)20160816180915.pdf http://downloadt.advantech.com/ProductFile/PIS/PCE-7129/Product%20-%20Datasheet/PCE-7129_DS(08.16.16)20160816180915.pdf
The machine has OS installed Linux Red-Hat 6.7.
Executing the command "turbostat" indicates that the speed of the TurboBoost with 4 active cores is of 4.0 GHz. This is correct?
Best regars
Hello rsf_89,
It is correct, on that image, you can see the Turbo Boost active.
I hope you find the information helpful.
Angie
