16880 Discussions
Intermittent slow running laptop
Rons_Son
I have an HP laptop running an11th Gen Intel® Core™ i7-1195G7 @ 2.90GHz.  While it is very fast normally, it can suddenly slow down greatly to a point where it is not useable with most apps.  When this happens I am eventually directed to the Intel Optane Memory and Storage Management app.  Unfortunately, virtually non of the tabs actually work, so I resort to rebooting a number of times before the CPU fan stats working and things return to normal.
Any advice on this frustrating issue would be very welcome.
Thanks, Ron's Son
Mike_Intel
Hello Rons_Son,
  1. What is the complete model of the laptop?
  2. When did you purchase this laptop?
  3. Was it working fine before?
  4. When did you start having this issue?
  5. Did you change any settings before the issue started?
  6. Is it overheating? Did you check the temperature?
  7. You mention about the CPU fan, when the system starts getting slow. Did you check if the fan is still spinning?
Michael L.
GXT1
You used the phrase ..I am eventually directed to the Intel Optane Memory.. is this from an error that pops up on the screen, Windows Event Log, or something else. What OS are you running. Are you getting related errors in the Windows Event Logs?
BTW if you are running an SSD as most of us are, I have personally run afoul of this type of behavior from an SSD starting to have problems. The computer I'm typing this on used to have an SSD that would cause short freeze ups and then release, some times up to a minute or so. I spend a lot of time using Task Manager and Perfmon to try and track down CPU consuming processes, except by the time they would open up the event was over (because they wouldn't open up until the event was over). I used Msconfig to limit the number of items that would boot on start up, uninstalled some software all to no avail until I decided to switch out the SSD.
The boot on this computer is a traditional 2.5" SSD, on my other computer it's an M.2 but either way they are both flash memory with a finite life cycle for data writes. It's like the old adage about motorcycle riders, those that have gone down and those that will.
I have USB doc stations for both types and use the doc stations to clone my drives both to protect against catastrophic failures and for a series of full backups that go back years. OS's are relatively easy to replace but data and the final configuration of the OS, not so much.
If you are having SSD issues (and don't have a full backup) better to try and get a clone of the drive before it becomes so degraded you can't.
Rons_Son
Thank you everybody.  I used the HP helpdesk, who found some Intel updates that were not easily visible.  A couple of re-boots later, and my i7 Intel laptop is flying along.  Thanks again.  Ron’s Son.
