Interrupts and QPI
if I understand correctly, QPI packets which contain data always transfer 64 bytes of data unless of course it is a header only transaction. What way are PCIe interrupts forwarded? Do they have a payload? (Better still, is there a QPI Spec available anywhere?)
Charles
Adolfo_S_Intel2
I would suggest contacting a Field Application Engineer (FAE) so they can assist you with your question.
You can contact a Field Application Engineer (FAE) by calling any of the Authorized Intel® Distributors and asking them to put you in contact with a FAE.
You can find a list of Authorized Intel® Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
If you are outside of North America, please check this link for a list of local Authorized Intel® Distributors:
http://premierlocator.intel.com/Default.aspx http://premierlocator.intel.com/Default.aspx
