17159 Discussions
Is 52 Degree to high in Bios for a i7 6700K?
i have a new Skylake system and I want to ask if 52 Degree to high in Bios for a i7 6700K CPU?
My System:
Case: Fractal Define R5 PCGH Edition
Ram: http://www.hardwareluxx.de/community/private.php?do=showpm&pmid=13182829 Kingston HyperX Savage 32GB DDR4
CPU: i7 6700K
Mainboard: ASROCK Z170 OC Formular
Cooler: Be Quiet Dar Rock 3
GPU: Palit 980 TI
Hello, blackstarr:
The TCASE for this processor is 64°C, so as long as you stay under that number your processor will be fine. However, I would like to check the following information;
Could you please let me know the part number of your RAM?
Is the 52 degrees in Fahrenheit or Celsius?
Have you tried taking out the motherboard from the chassis? Is the temperature the same?
Amy.
Hello, blackstarr:
Was the information posted above helpful for you? I am following up your thread, so please let me know if there is something else I can help you with?
Amy.
