16885 Discussions
Kernel Panic on i7-13700 with CR0 Modification in Linux 6.8+, but Not on i7-14700 or i7-8700K
lsm_panic
Hello Intel Community,
I'm experiencing a kernel panic on my Intel Core i7-13700 (13th Gen, Raptor Lake) when modifying the CR0 register in a C program with inline assembly. This issue occurs only on Linux kernel versions 6.8 and above (tested on 6.8 and 6.10). Interestingly, I tested the same code on systems with Intel Core i7-14700 (14th Gen) and i7-8700K (8th Gen), and no kernel panic occurs on those CPUs. I suspect this may be related to the reported 13th Gen instability issues.
System Details:
  • CPU: Intel Core i7-13700
  • OS: Ubuntu [24.04], Alma 10, Linux kernel 6.8+
  • BIOS: Vendor: Phoenix Technologies LTD, Version: 6.00, Release Date: 11/12/2020
  • Microcode: 0x12F (confirmed via cat /proc/cpuinfo | grep microcode)
Issue Description
My program toggles the CR0 Cache Disable (CD) bit using inline assembly. Below is the simplified code:
This code works fine on kernel 6.7 or lower, as well as on i7-14700 and i7-8700K systems running kernel 6.8+. However, on the i7-13700 with kernel 6.8+, it triggers a kernel panic immediately after the mov %0, %%cr0 instruction. The dmesg log shows a general protection fault or triple fault. I have attached the panic log capture below (via Pastebin or as an attachment).
Questions:
  1. Is this related to the known Raptor Lake voltage instability issue? Why does it only affect i7-13700 and not i7-14700 or i7-8700K?
  2. Are there specific kernel patches in 6.8+ that could affect CR0 handling?
  3. Any debugging tips (e.g., specific dmesg flags or tools like Bochs)?
  4. Should I contact Intel for an RMA, or is this likely a software issue?
Any insights or similar experiences would be greatly appreciated!
Thank you!
JeanetteC_Intel
Hello lsm_panic,
Thank you for contacting Intel Communities. I'm reviewing this matter internally and will respond with an update when available.
JeanetteC.
JeanetteC_Intel
Hello lsm_panic,
Please check your email for a private message containing an update on this issue. Make sure to review your inbox, spam, and junk folders, as the email may have been filtered there.
JeanetteC.
