16885 Discussions
MB DH87RL doesn't post with i5-4570
DSaon
With this configuration:
PSU Corsair CX500
MB DH87RL
CPU I5-4570
RAM Kingston Fury 2x4 MB 1600
SSD Kingston HyperX 128 GB
the mb doesn't post
PSU Corsair CX500
MB DH87RL
CPU I3-4130
the pc work fine.
Please help me to find a solution.
Kevin_M_Intel
Hi SINAC_Diego,
It is too bad you are having this problem but let me help you.
Based on the information online, this processor is fully compatible with the motherboard so there are some troubleshooting steps you can try for testing purposes:
  1. Take the motherboard outside of the case if possible over a Wood Surface or glass to avoid grounding issues.
  2. Use the system with minimum configuration. Just with 1 HDD, 1 memory Stick, no video cards or Audio cards.
  3. Test the faulty processor in another motherboard if possible. If it fails there means the processor is damaged and will be necessary to replace it.
