16769 Discussions
Max Memory Bandwidth of Intel Xeon X5690 and X5680 Proccesor
I had one question regarding with the Intel latest Xeon processor X5690.
I noticed that the Maximum Memory Bandwidth for Intel Xeon X5690 (25.6GB/s) are different with Intel Xeon X5680 (32 GB/s).
However the other memory specifications such as memory type, no of channels, and physical address extensions are identical. I'm curious about the different of memory bandwidth between these two processor that supposed to be identical accept for core speed.
Is it a typo error from Intel or they had make some changes to their design in this new Xeon X5690 processor?
Thank you.
Adolfo_S_Intel2
We have not made any recently change to the processors, I would recommend checking the following link to find the differences between both processors: http://ark.intel.com/Compare.aspx?ids=52576,47916, http://ark.intel.com/Compare.aspx?ids=52576,47916,
Adolfo_S_Intel2
DSilv11
Valued Contributor III
Sent a message to the processor team. Web site should be corrected shortly.
Thanks for your reply, it seem that the max memory bandwidth for these two processors are same now.
DSilv11
(Wow, They are faster than I thought. )
yes, i was suprised too.
