17152 Discussions
My Intel I5 760 is running at 2.00 GHz of max speed
IItsW
I don't know why. But before it was running just fine at 2.80 GHz. But It's running at 2.00 Ghz, Well that is the max frequency, my motherboard is tell me that, and my OS too.
Anyone has a solution for this?
n_scott_pearson
I would suggest that you check the configuration in (the limitations being imposed by) your system's BIOS. As well, check the related configuration in your O/S (In Windows, check the Power Options applet in Control Panel)..
Hope this helps,
n_scott_pearson
Hope this helps,
Thank you, Scott for the recommendations provided!
Please let us know how it goes, ItsWolfPT
Esteban C
IItsW
(Slow Reply: I was busy so I couldn't answer in time Sorry.)
Thx It help. the problem was on my BIOS CPU settings. Base clock was 15x, and I press F7 for optimization to default settings and It works . So Thx a lot. N.Scott.Pearson
That sounds great, ItsWolfPT
In case you require any further support in the future, feel free to reach us here or any other customer service platform.
Esteban C
