16975 Discussions
My mouse not working Because of outdated CPU driver
ErsinAymbetov8
My CPU is: Intel pentium e5300 2.6Hz
Please give me driver download link
AlHill
"My mouse not working Because of outdated CPU driver
My CPU is: Intel pentium e5300 2.6Hz"
Rubbish.  Absolute rubbish.
[If you find any Intel driver you might need, download and save it now.]
ErsinAymbetov8
I am download INtel driver and Support assistant but its not working. I cant find driver
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
ErsinAymbetov8
here is
n_scott_pearson
First of all, your processor is from 2008 and is not supported by Intel with Windows 10/11 and is certainly not supported by the iDSA application. Only Microsoft's inbox compatibility drivers will allow this platform to work (if at all).
Secondly, understand that there would be no discrete driver packages for the processor as all major peripheral subsystems - memory, graphics, USB, SATA, etc. - were all contained within the chipset. The drivers for this chipset are, for platforms this old, inbox with Windows 10/11.
Reality Bites. Time for a system upgrade.
