17162 Discussions
My pc is not performing well
VanQuish
My pc is not performing upto its full potential specially processor,i play games like valorant and counter strike 2 and i am getting 30 to 40 fps in counter strike 2 on low settings and around 70 to 80 fps in valorant also on low settings.I tried everything disabling background apps ,disabling v-sync,high performance mode etc everything.
My PC specs are:
Core i3-10100
MSI H510m motherbard
GTX 1070 8GB
16 GB 2666MHZ RAM
  • 1
ACarmona_Intel
Hello VanQuish,
Please generate an SSU report to help me further analyze your system specifications and configurations.
To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
Furthermore, were Valorant and Counter-Strike 2 working fine before? If yes, have you made any changes before the issue occurred?
Carmona A.
ACarmona_Intel
Hello VanQuish,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
Hello OnurKARABULUT,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
