16889 Discussions
Need XHCI Root Hub Drivers
BFran17
Just installed a USB PCIE 4 Port card in my IBM MT-M8141 Desktop. Card drivers are fine but the Root Hub is not installed with an Error Code 28. Are specific or generic drivers available for this situation? They were not located on the install disc. This may not be the correct place to post this but it was as close as I could find. Thanks!!
BFran17
USB Bus Adapter Controller is Intel 82801 265A-C.
AlHill
What operating system and version? Windows 10, version 1909?
What is your processor model number?
Doc
BFran17
Windows 7 32 bit with latest SP. Intel Pentium 4 3.0Gz.
AlHill
I do not know if it will work for you but you can try the attached:
Doc
AlHill
Also, you know W7 is dead, right?
Doc
BFran17
Yes, I do know Win 7 is "past it's sell by date" but there are programs on it Win 10 will not run. Thanks for the files - I'll check them soon!! Bobby
BFran17
I'll report back one way or another.
BFran17
I t​ried installing the software you sent me yesterday and it said "the system did not meet the minimum requirement to install". Let me know if you have any other suggestions or if we are at the end of the road. Many thanks for all your help so far!! BOBBY
BFran17
​I ran a "repair" program for the drivers and it ran successfully. After that, the drive was visible. We will see if it continues to work but presently, all is now well!! Thanks, Al, for all your help!! Bobby
AlHill
Glad you have it working.
Doc
