16855 Discussions
Need a little help with Intel Extreme Tuning (using an I5-2500K)
Hi all,
I'm trying to get another solid year or two out of my CPU and bought it with the intent to overclock one day (that day is nigh ).
Here are my specs:
Win 10 Pro 64bit
CPU - Intel Core i5 2500k @ 3.30 Ghz, Sandy Bridge 32nm Tech
8GB Dual Channel DDR3 ram @ 688mhz
Motherboard: ASUSTEK Computer INC P8Z68-V LE (LGA 1155)
GFX: 2048 ATI AMD Radeon 6850
POWER: 650W Antec
When I go to Intel Extreme Tuning Utility, under advanced tuning, pretty much everything is greyed-out. Is my motherboard no supported (I thought it was when I purchased it), or something else I may not be aware of? Also to note, I have four fans, currently running at medium and plan on turning them up.
Thanks in advance for any help -- I'm really looking forward to getting a modest CPU boost and upgrading to the Sapphire Nitro 8gb gfx card.
(I'm attaching a rather large screenshot at the bottom, note every field is grey )
Best,
Chuxx
Would this be because my BIOS are a few years old? I really don't want to mess with those, so I'm trying to eliminate all other possibilities.
In regard to the processor specifications, this is an unlocked unit. This means Intel® XTU features should be available. Please bear in mind that all XTU features are available if the BIOS of the computer enables such options as well.
Please check with your motherboard maker for BIOS updates, if you have an earlier version, you may want to update them gradually.
https://www.asus.com/Motherboards/P8Z68V_LE/HelpDesk_Download/ Asus driver website
Allan.
