17151 Discussions
Need suggestion for processor upgrade
pa4
I have planned to upgrade the laptop processor, please find Chipset details below,
Chipset
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel HM65 rev. 05
Memory Type DDR3
Memory Size 2 GBytes
Channels Single
Memory Frequency 665.1 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Current Processors Information
Processor 1 ID = 0
Number of cores 2 (max 8)
Number of threads 2 (max 16)
Name Intel Pentium B950
Codename Sandy Bridge
Specification Intel(R) Pentium(R) CPU B950 @ 2.10GHz
Package (platform ID) Socket 988B rPGA (0x4)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 35 Watts
Tjmax 85.0 °C
Core Speed 798.1 MHz
Multiplier x Bus Speed 8.0 x 99.8 MHz
Stock frequency 2100 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 MBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
Can you please suggest latest Processors that fit for this Chipset….
