16773 토론
New 12900K build, getting thousands of WHEA-Logger (Event ID: 17) errors a minute
gcassie
초보자
21,872 조회수
Ref: New 12900K build, getting thousands of WHEA 17 errors a minute - Intel Communities
Gigabyte Support Issue ID: 1437
A corrected hardware error has occurred.
Event Viewer shows the following details:
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x0:0x1:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_460D&SUBSYS_50001458&REV_02
Secondary Device Name:
From the Windows Device Manager:
System devices->Intel® PEG10 – 460D
Manufacturer: INTEL
Device Status: This device is working properly.
Driver: 10.1.45.9
Hardware id: PCI\VEN_8086&DEV_460D&SUBSYS_50001458&REV_02
Gigabyte Technology Co., Ltd. Z690 UD DDR4
BIOS Version: F22
Date: 12/7/2022
MOTHERBOARD
Manufacturer: Gigabyte Technology Co., Ltd.
Model: Z690 UD DDR4
Version: R.1
OPERATING SYSTEM: Microsoft Windows 11 Pro (64-bit)
Version (Build): 22H2 (10.0.22621)
Devices and Drivers
PROCESSOR: 12th Gen Intel® Core™ i9-12900K
Manufacturer: GenuineIntel
Description: Intel64 Family 6 Model 151 Stepping 2
Architecture: x64
# of Cores: 16
# of Threads: 24
Processor Base Frequency: 3200 MHz
Current Voltage: 1.6
Level 2 Cache: 4096 Kb
Level 3 Cache: 30720 Kb
Processor Id: 0x90672
Availability: Running at full power
GRAPHICS: NVIDIA GeForce RTX 3080
Intel® UHD Graphics 770
AUDIO: NVIDIA High Definition Audio
Logitech G560 Gaming Speaker
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Realtek High Definition Audio
NETWORKING AND I/O: Realtek Gaming 2.5GbE Family Controller
TAP-Surfshark Windows Adapter V9
MEMORY: 96 GB
STORAGE: Samsung SSD 970 EVO Plus 1TB
Samsung SSD 980 PRO 2TB
OTHER: Intel® Management Engine Interface #1
Others experiencing the same thing.  Only solution so far is putting GPU in 2nd PCI slot running at GEN 3 speeds (kinda beats the point of having a GEN 4 card).
Someone with a similar issue here: https://community.intel.com/t5/Processors/WHEA-LOGGER-ID17-help/m-p/1328866#M54659
https://www.reddit.com/r/ASUSROG/comments/r35jsw/rog_strix_z690a_gaming_wifi_whea_17_error/
and
https://www.reddit.com/r/gigabyte/comments/r0wa1o/z690i_aorus_ultra_ddr4_pcie_whea_errors/
BIOS Updated
Drivers all updated
Windows 11 OS Updated
This issue is causing poor performance and crashes.
The motherboard, CPU, memory and SSD are brand new
Please advise appears to be a Manufacturer: Gigabyte Motherboard Model: Z690 UD DDR4 issue for many people?
Judging by the numerous of posts on Reddit, this problem has affected every owner of this motherboard.
It seems to be the motherboard, even though it's happening across multiple board makers.  On my Gigabyte Aorus Z690-I ultra ddr4, manually setting the GPU PCIe slot to 3.0 makes all the errors go away, and over on the Gigabyte Reddit forum, someone who appears to be a Gigabyte employee says they're planning on replacing affected boards, but they're not ready yet.
Is there a fix or will my Gigabyte Motherboard Model: Z690 UD DDR4 be replaced under warranty?
Or will INTEL Update the Drivers?
0 포인트
12 응답
Jocelyn_Intel
직원
21,839 조회수
Hello, @gcassie
Thank you for posting on the Intel® communities.
I am sorry to hear what is happening with your computer, I will gladly assist you here.
Please, run this utility and attach the report so we can investigate this issue:
Intel® System Support Utility for Windows.
Note: Make sure to mark the box that says "everything" before pressing the Scan button. After that, click on "Next>" and select "Save" and then, attach the .txt file.
Best regards,
Jocelyn M.
Intel Customer Support Technician.
0 포인트
gcassie
초보자
21,827 조회수
CMOS cleared and the issue remains
Ref. The re-run Intel SSD Report:
Intel SSD Report 10-Mar-2023 (Greg Cassie PC following BIOS CMOS Reset).txt
Note: I am unable to attach the
Windows Event Viewer -> Windows System Log File: Windows System Event Log 10-Mar-23.evtx
Screenshots:
Furthermore, I have run the Intel Processor Diagnostic Tool
Ref. TESTRESULTS.TXT
Ref. TestResults_Full.txt
Manufacturer: INTEL
Driver: 10.1.45.9
This on-going issue causes my PC to crash and reboot.
Greg Cassie
0 포인트
Jocelyn_Intel
직원
21,811 조회수
Hello, @gcassie
Thank you for the information provided.
Let me do some research about this issue, as soon as I have updates, I will post them here.
Best regards,
Jocelyn M.
0 포인트
gcassie
초보자
21,788 조회수
Some further fault-finding checks:
Ref. Gigabyte Z690 UD DDR4 Motherboard mb_manual_z690-ud-series_e_1101.pdf
Expansion Slots
1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
(The PCIEX16 slot conforms to PCI Express 5.0 standard.)
1 x PCI Express x16 slot, running at x4 (PCIEX4)
1 x PCI Express x16 slot, running at x1 (PCIEX1_4)
3 x PCI Express x1 slots
2 x PCI Express x1 slots
(The PCIEX4 and PCIEX1 slots conform to PCI Express 3.0 standard.)
Connected GPU NVIDIA GeoForce RTX 3080 to:
System WHEA Logger 17 Errors occur
Note: * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  • 1 x PCI Express x16 slot, running at x4 (PCIEX4)
  • or
NO System WHEA Logger 17 Errors occur
Ref. GeForce-RTX-3080-VENTUS-3X-10G-OC.pdf
Model Name GeForce RTX™ 3080 VENTUS 3X 10G OC
Graphics Processing Unit NVIDIA® GeForce RTX™ 3080
Interface PCI Express® Gen 4
Connected: PCIEX4 NO System WHEA Logger 17 Errors occur
  • Connected: PCIEX16 System WHEA Logger 17 Errors occur
In summary, the errors occur when GPU NVIDIA GeoForce RTX 3080 connected to PCIEX16, PC unstable and crashes
No errors occur when GPU NVIDIA GeoForce RTX 3080 connected to PCIEX4 OR PCIEX1_4, PC stable, poor performance.
Issue is a motherboard / processor / GPU driver / hardware compatibility issue.
Motherboard: Manufacturer: Gigabyte Technology Co., Ltd. Model: Z690 UD DDR4 Version: R.1
GPU: NVIDIA GeForce RTX 3080
0 포인트
gcassie
초보자
21,756 조회수
Additional Testing with GPU (NVIDIA GeoForce RTX 3080) connected to connected to PCIEX16 and changing BIOS Settings:
BIOS Menu
BIOS Selection
Options
Selected
Selected
Selected
Selected
Selected
Selected
Miscellaneous
CPU PCIe Link Speed:
Auto, GEN1, 2, 3, 4 or 5
Auto
3
5
4
3
4
Miscellaneous
PCH PCIe Link Speed:
Auto, GEN1, 2, 3, 4
Auto
3
3
3
4
3
IO Ports
PCIE Bifurcation Support
Auto or PCIE x8/x8
Auto
Auto
Auto
Auto
Auto
PCIE x8/x8
Events: WHEA Logger 17 Errors
Yes
No
Yes
Yes
No
Yes
In summary, CPU PCIe Link Speed: >3 Error Occur Events: WHEA Logger 17 Errors and System Unstable, when GPU (NVIDIA GeoForce RTX 3080) connected to connected to PCIEX16
As previously defeats the purpose having a PCIE GEN 5 CPU / GEN4 GPU and only stable operation at GEN 3 CPU PCIe Link Speed.
Ref. BIOS Info: Gigabyte Z690 mb_manual_600series-bios_e_v2.pdf
CPU PCIe Link Speed: Allows you to set the operation mode of the CPU-controlled PCI Express slots to Gen 1, Gen 2, Gen 3, Gen 4 or Gen 5 (Note). Actual operation mode is subject to the hardware specification of each slot. Auto lets the BIOS automatically configure this setting.
PCH PCIe Link Speed: Allows you to set the operation mode of the chipset-controlled PCI Express slots to Gen 1, Gen 2, or Gen 3. Actual operation mode is subject to the hardware specification of each slot. Auto lets the BIOS automatically configure this setting.
PCIE Bifurcation Support: Allows you to determine how the bandwidth of the PCIEX16 slot is divided. Options: Auto, PCIE x8/x8
0 포인트
Jocelyn_Intel
직원
21,713 조회수
Hello, @gcassie
Thank you for your time.
Have you tried reinstalling the OS? Does the issue persist after an OS clean reinstallation?
Best regards,
Jocelyn M.
0 포인트
gcassie
초보자
21,694 조회수
Jocelyn,
I can confirm Windows 11 OS was reinstalling with a clean installation from USB.
The WHEA-Logger (Event ID: 17) errors existed, with the previous Windows 11 OS installation and also following clean installation.
Greg
0 포인트
Jocelyn_Intel
직원
21,679 조회수
Hello, @gcassie
Thank you for your confirmation on this.
We will proceed to investigate further about this matter, as soon as I have updates, I will post them here.
Best regards,
Jocelyn M.
0 포인트
Jocelyn_Intel
직원
21,652 조회수
Hello, @gcassie
Since the issue persists after an OS reinstallation, we recommend you to check with the Motherboard Manufacturer if a Chipset driver installation may be recommended and install it or any other possible recommendations.
Best regards,
Jocelyn M.
0 포인트
gcassie
초보자
21,582 조회수
Jocelyn,
ISSUE REOLVED! - Error Occur Events: WHEA Logger 17 Errors when GPU (NVIDIA GeoForce RTX 3080) connected to connected to PCIEX16.
I followed up with GIGABYTE Support (Email-ID: 1439277)
The cause of the issue was related to the PCIE Gen 4.0 riser cable. The issue was resolved by mounting my graphics card horizontally, direct to the PCIEX16 slot, and not using the PCIE riser cable.
Note: The likely cause of the significant WHEA Logger 17 Errors and PC instability, is likely due to electromagnetic interference.
BIOS Selection, with no: WHEA Logger 17 Errors
CPU PCIe Link Speed: Auto
PCH PCIe Link Speed: Auto
CPU, RAM & GPU Stress Test, completed with no error.
Thanks for your support!
0 포인트
Jocelyn_Intel
직원
21,571 조회수
Hello, @gcassie
I am happy to hear that your issue was solved, I appreciate you letting us know about this issue in our community.
Since your issue is solved, we will proceed to close this thread now.
Have a nice rest of the week.
Jocelyn M.
0 포인트
Magnarks
초보자
17,460 조회수
Hello, I have the same problem, but I have my GPU connected directly to the board horizontally, and it is AMD not Nvidia, I have already tried reinstalling the GPU and the drivers, but nothing.
0 포인트
응답
