16790 討論
Number of processors in i5-2520M
員工
2,863 檢視
Can anyone tell me how many processors there are in i5-2520M? I'd like to use the info to change the advanced boot settings in Windows 7. And by the way, does it drastically increase the speed in Windows 7 by changing the number of processors?
0 積分
3 回應
員工
1,458 檢視
You can use this link which shows that the processor under question is a 2 core 4 thread processor: http://ark.intel.com/products/52229?wapkw=(i5-2520M http://ark.intel.com/products/52229?wapkw=(i5-2520M). If you try reading about "SSD Optimization" it is suggested that you should set the number of processor in the boot menu to maximum. You might get a slight increase in startup speed but not really too significant.
員工
1,458 檢視
Thanks for the reply, Boyet. I couldn't find anything about "SSD Optimization" in the link you sent me, but when it is suggested that you should set the number of processor in the boot menu to maximum, I guess in my case it would mean setting it = 2? Or should I set it to the maximum (4) available in the dropdown menu?
員工
1,458 檢視
The link that I have provided earlier is for the processor only. For the optimization you can access this link http://thessdreview.com/ssd-guides/optimization-guides/the-windows-7-optimization-guide/ http://thessdreview.com/ssd-guides/optimization-guides/the-windows-7-optimization-guide/. Look under Faster Boot, Configuration File Adjustment.
回覆
