16766 Diskussionen
Only cursor displayed in monitor
rsonk
Neuer Beitragender I
2.755Aufrufe
Copy movies from usb codec error when played cpu rhttp://goo.gl/u8P6ME eading seems normally a day after when start pc the problem occur stack up cursor just. blink
5 Antworten
amevi
Einsteiger
1.868Aufrufe
Try a bootable media (DVD/USB) to repahttp://goo.gl/8Ur2QK ir the "Startup Repair" option.
rsonk
1.868Aufrufe
1. Remove all floppy disks, CDs, and Dhttp://goo.gl/maoapk VDs from your computer, and then restart your computer.
2. Press and hold the F8 key as your computer restarts.
3. On the Advanced Boot Options screen, use the arrow keys to highlight Enable low-resolution video (640×480), and then press Enter.
If the problem doesn't reappear in low-resolution mode, then the issue is driver related. You can resolve this by downloading display card driver from the manufacturer's website.
amevi
Einsteiger
1.868Aufrufe
i think your graphics card is failing, probably due thttp://goo.gl/maoapk ooverheating. you need to take it to a repair shop, they'll clean it up for you.
rsonk
1.868Aufrufe
My computer (windows vista buisness 32-bit) got a BAD virus that would create a new virus everytime a program is opened, and give me an error message something like "Runtime error access is denied, press OK to termiate the process". I shttp://goo.gl/HBR5JL canned my comp, it deleted 1121 viruses, and asked me to restart my computer, I restarted, and ended up just like you, a blank screen with a mouse. this is because no processes are running. press control alt delete and select task manager. under Applications select "new task" type in explorer and press enter. you should see your background image and the taskbar as well as your icons. but other processes arent running. for example, i normaly get widows sidebar when I start, nowi dont. my plan is to back up everything and re-install the OS because it is all screwed up. then ill be okay. hope this helps.
Mitarbeiter
1.868Aufrufe
Hello, All:
Thank you for your feedback.
Amy.
Antworten
