17350 Discussions
PCI Data Acquisition and Signal Processing Controller
CMCDS
I have a problem with the "PCI Data Acquisition and Signal Processing Controller" driver not being installed. Is there a solution for this issue?
I have attached the system report.
I appreciate your help.
pressed_for_time
Valued Contributor III
There should be a Intel chipset driver download available for your machine from the vendor of your device. Installing this driver should fix the issue.
