16791 Discussions
Passmark PerformanceTest index on i7
LBish
measured CPU only performance index with Passmark I only reach overall indexes between 6600-6800 pts. while other configurations using same CPU reach values over 7900 pts. Might this be a poor CPU speed or influenced by other factors (exact CPU ID is i7-4700MQ). Thanks for answers.
Silvia_L_Intel1
Hello BeLzEnUb, I would recommend you to try the Intel® Processor Diagnostics Tool to see if it shows up any error.
http://www.intel.com/support/processors/sb/CS-031726.htm http://www.intel.com/support/processors/sb/CS-031726.htm
Please remember that Intel doesn't validate 3rd party tools as per diagnosing our products.
LBish
Hi sylvia_intel, I know about the tool. It didn't work for me firstly but after disabling Hyper-V it is pass successfully. I assume processor is working good. But performance seems noticeably lower than should be using 3rd party benchmark.
Can you recommend a tool from Intel to verify CPU performance is at expected index..
Silvia_L_Intel1
BeLzEnUb, the processor you are using is a OEM product. We provide the hardware to the system manufacturer and they will design the drivers specifically for their systems.
If you are not satisfy with the performance of this processor, I would recommend you to contact your computer manufacture and ask them if there is a new BIOS version available that needs to be install on your system.
Processor Diagnostics Tool is the only tool we have available.
