I need to get a design program for work. The processor requirements for this program are a Pentium 4 2.0 GHz or an AMD Anhlon XP 2400 (or faster). My laptop computer has an Intel Core 2 Duo CPU processor.
Will the new design program work within my existing laptop?
Thanks in advance!!
MDKB
The Intel® Core™2 Duo Mobile Processor should be sufficient to comply with a software requirement of a Pentium 4 or better CPU. Which CPU do you have in your laptop?
More information on Intel® Core™2 Duo Mobile Processors can be found at the following links: http://ark.intel.com/ProductCollection.aspx?familyID=26548 http://ark.intel.com/ProductCollection.aspx?familyID=26548 and http://processorfinder.intel.com/List.aspx?ProcFam=2643 http://processorfinder.intel.com/List.aspx?ProcFam=2643 .
In case you're interested, check out the new Intel® Processor Ratings: http://www.intel.com/consumer/rating.htm http://www.intel.com/consumer/rating.htm
John
Hi JohnS,
Thanks for replying! If I look in my control panel under the "system" icon, my processor is noted as a:
Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz 1.50 GHz
Hope that helps!
Thanks!
mdkb
The processor you have should work just fine with the software you are trying to use.
