16832 Discussions
Performance per watt
cyp
Hi fellow CPU manufacturer.
I'm just curious, it's not about an issue with my Intel products, if I should ask somehwere else just tell me where to !
I was wondering if I could get some infos about the performance per watt at different frequencies / CPU-governor of some CPUs (at least my i5 10210U). I've seen some quite old benchmarks (https://www.phoronix.com/review/intel_pstate_linux315/3) and  my doubt increased about the worthiness of powersave p-state
For exemple given a certain amount of WattHour, with which governor/ frenquency will I accomplish more operations. I'm was trying to subtly set my battery setting on my laptop when this scientific question came in my mind.
Thanks in advance if you have the time to read / answer me.
Alberto_R_Intel
cyp, Thank you for posting in the Intel® Communities Support.
In reference to your question, in order for us to be able to provide the most accurate assistance in this scenario, we will do further research on this matter. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello cyp, I just received an update on this matter.
In reference to your inquiry, please check the datasheet of the Intel® processor for the power management section on page 58 volume 1. It provides details about P-states and AHCI information. The data in there refers to the processor itself; however, it is important to mention that it is needed to have into consideration the whole system's requirements:
https://www.intel.com/content/www/us/en/products/docs/processors/core/core-technical-resources.html
Albert R.
Alberto_R_Intel
Hello cyp, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello cyp, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
As an option, you can also get in contact directly with the manufacturer of the laptop for further details on this matter.
Albert R.
