16871 Discussions
Please Help to Identify Processor
bkm
Hai,
purchased original intel cpu+mobo in Jan 2005 and both has reached EOIS. System has been working fine till recently, but now showing problems whenever any PCI component is added. Either XP will not shut down, or added component's driver will not work properly or will get 'cmos checksum bad' message every time i boot and so on..The local techie told me that my mobo is faulty. My cpu is still working fine and i feel no need to change it since it meets all my requirements.So i need to find a third party mobo as Intel original is no more avalable and for that i need to identify my cpu and i am having nightmares doing that.Having spent more than 24 hours in internet trying to figure it out, and am getting more confused and frustrated by time.
There is no exact match between....
  1. cpu name
  2. processor number
  3. sSpec number
  4. box part number
  5. Bus/Core ratio or Multiplier
  6. TDP etc..
ANY HELP IS HIGHLY APPRECIATED. Adding details here...
Intel(R) Processor Identification Utility
Version: 4.32.20110608
Time Stamp: 2011/10/18 14:17:10
Operating System: 5.1-2600-Service Pack 3
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 1
Disabled cores per processor: 0
Processor Name: Intel(R) Pentium(R) 4 CPU 3.00E GHz
Type: 0
Family: F
Model: 3
Stepping: 4
Revision: 17
Maximum CPUID Level: 5
L1 Trace Cache: 12 Kµops
L1 Data Cache: 16 KB
L2 Cache: 1 MB
Packaging: FC-PGA2
Platform Compatibility Guide: 04A
Enhanced Intel SpeedStep(R) Technology: No
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: No
Intel(R) AES-NI: No
Intel(R) AVX: No
Enhanced Halt State: No
Execute Disable Bit: No
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: No
Intel(R) Virtualization Technology: No
Expected Processor Frequency: 3.0 GHz
Reported Processor Frequency: 3.0 GHz
Expected System Bus Frequency: 800 MHz
Reported System Bus Frequency: 800 MHz
Intel(R) Board ID Tool
Version: 1.0.1.1
Board Model: D865GBF
Board Version: AAC25827-410
Bios Version: BF86510A.86A.0069.P21.0409290100
bkm
hai mukata thanks for the reply. But it is not correct. The box in which it came has 'Pentium 4 Processor 3E GHz, 1 Mb L2 Cache, 800 MHz FSB' written on it(see photos uploaded in my first post). So it cannot be just '3 Ghz'. The problem with '3E GHz' specification in Intel site is that it lacks CPU Multiplier, but EVEREST Home Edition says my cpu has 15.0x multiplier. Also if you search using Box Part Number or sSpec Number as seen in the package, 3E GHz is not listed in the site. Any ideas?
DSilv11
Valued Contributor III
Thats an older one, buy you have provided all the right data
CMOS checksum bad sounds like a dead cmos battery allowing the CMOS to be corrupted with AC is removed and loosing any CMOS settings.
http://ark.intel.com/products/27463?wapkw=sl7e4 http://ark.intel.com/products/27463?wapkw=sl7e4
  1. cpu name prescott
  2. processor number 530 / 530j
  3. sSpec number SL7E4
  4. box part number RK80546PG0801M, BX80546PG3000E,
  5. Bus/Core ratio or Multiplier 15
  6. TDP etc.. 84w
bkm
hai Doc_SilverCreek thanks for the reply. But it is not correct.As per EVEREST Home Edition, the Package Size of my cpu is 35.0 mm x 35.0 mm but the one stated in the link given by you is 37.5mm x 37.5mm. Also the box came with 'Pentium 4 Processor 3E GHz, 1 Mb L2 Cache, 800 MHz FSB' (see photos in my first posting) written on it and that has no Processor Number in the site. So it cannot be 530 / 530j. The problem with '3E GHz' specification in Intel site is that it lacks CPU Multiplier, but EVEREST Home Edition says my cpu has 15.0x multiplier. Also if you search using Box Part Number or sSpec Number as seen in the package, 3E GHz is not listed in the site. Any ideas?
DSilv11
So it comes down to the report of a piece of freeware software or the manufacture specification page?
I have seen the Intel page be wrong before -- once
i have seen everest report a Xeon WSM 5695 as a PIII
DSilv11
http://download.intel.com/design/Pentium4/datashts/30235104.pdf http://download.intel.com/design/Pentium4/datashts/30235104.pdf page 36 cpu is 37.45mm to 37.55mm
/message/59171# 59171 http://communities.intel.com/message/59171# 59171
'E' designator:
This letter designator identifies Pentium® 4 processors that are manufactured using the 90 nanometer process with 1MB L2 Advanced Transfer Cache.
bkm
Hai i am adding EVEREST Home Edition report also. Please help me identify my processor.
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/ http://www.lavalys.com/
Report Type Report Wizard
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2011-10-19
Time 11:54
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 3
DirectX 4.09.00.0904 (DirectX 9.0c)
Motherboard:
CPU Type Intel Pentium 4, 3000 MHz (15 x 200)
Motherboard Name Intel Bay Field D865GBF (6 PCI, 1 AGP, 4 DIMM, Audio, Video, LAN)
Motherboard Chipset Intel Springdale-G i865G
System Memory 240 MB (PC3200 DDR SDRAM)
BIOS Type AMI (09/29/04)
Communication Port Communications Port (COM1)
Communication Port Printer Port (LPT1)
Display:
Video Adapter Intel(R) 82865G Graphics Controller (96 MB)
3D Accelerator Intel Extreme Graphics 2
Monitor LG StudioWorks / HiSync 700B [17" CRT] (150312446)
Multimedia:
Audio Adapter Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
Storage:
IDE Controller Intel(R) 82801EB Ultra ATA Storage Controllers
Floppy Drive Floppy disk drive
Disk Drive ST380011A (80 GB, 7200 RPM, Ultra-ATA/100)
Optical Drive SONY DVD RW AW-G170A
SMART Hard Disks Status OK
Input:
Keyboard Easy Internet Keyboard
Mouse Logitech-compatible Mouse PS/2
Network:
Network Adapter Realtek RTL8139 Family PCI Fast Ethernet NIC (192.168.1.2)
Peripherals:
USB1 Controller Intel 82801EB ICH5 - USB Controller [A-2/A-3]
USB2 Controller Intel 82801EB ICH5 - Enhanced USB2 Controller [A-2/A-3]
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Prescott
CPU Stepping D0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 3.00GHz
CPUID Revision 00000F34h
CPU Speed:
CPU Clock 2994.16 MHz (original: 3000 MHz)
CPU Multiplier 15.0x
CPU FSB 199.61 MHz (original: 200 MHz)
Memory Bus 199.61 MHz
CPU Cache:
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties:
Motherboard ID 63-0100-000001-00101111-092904-iSPGDL_G$BF865001_BIOS DATE: 09/29/04 01:00:48 VER: 08.00.10
Chipset Properties:
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
PAT Disabled
SPD Memory Modules:
DIMM1 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133 MHz)
BIOS Properties:
System BIOS Date 09/29/04
Video BIOS Date 11/17/20
DMI BIOS Version BF86510A.86A.0069.P21.0409290100
Graphics Processor Properties:
Video Adapter Intel 82865G Graphics Controller [A-2]
GPU Code Name Springdale-G (Integrated 8086 / 2572, Rev 02)
GPU Clock 266 MHz
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Prescott
CPU Stepping D0
Instruction Set x86, MMX, SSE, SSE2, SSE3
Original Clock 3000 MHz
Min / Max CPU Multiplier 14x / 15x
L1 Data Cache ...
