16804 Discussions
Possible replacement Motherboards
dlim
I have a MSI Trident 3 8rc-006ca i7 8th gen. The motherboard has finally crapped out.
I am curious as to what i can do/use  (replace oem or upgrade)
Intel LGA-1151 mATX motherboard, DDR4 2666MHz, SATA 6Gbps and USB 3.1 Gen 1
-ASUS Prime H310M-A R2.0/CSM LGA1151
SUS TUF H310-Plus Gaming LGA1151
AlHill
No recommendations here.   Get whatever meets your needs.    HOWEVER.....   make sure your processor is supported by the motherboard bios.   It is not enough to be socket compatible.
