Problem I7-2600
mahmoudwe115
I have a computer whose temperature rises to 65% without load.
The processor is fanless from the beginning
Processor usage reaches more than 90%.
AlHill
That processor is almost 14-years-old.  make sure you case fans are working and there is adequate ventilation.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
mahmoudwe115
Maybe it is hyper threading (enable)
that is the reason
AlHill
Was hyper-threading on before the problem occured?
n_scott_pearson
You are seeing 93c while running only BIOS? Your processor is roasting. You have inadequate cooling.
What do you mean by "The processor is fanless from the beginning"? Unless you have a special chassis - which you obviously don't - a heatsink and cooling fan is an absolute requirement for this processor.
