16771 Discussions
Problems with i5-2500k maybe??
i bought this intel i5-2500k processer 2 weeks ago, did a new build. with the following
motherboard-- MSI, P67A-C43 S1155
processor-- Intel i5 2500K S1155 3.30 unloked
Antec Kuhler H20 Liq
memory-- DRR3 8GB 1333MHz Patriot
graphics-- Asus GTX550 Ti OC 1GB
hard drive--Seagate Barracuda 500GB Serial ATA/6GB
power supply-- Raidmax 630w PSU
OS-- Win7 SPI Home 64bit
right after installing win7 started crashing getting blue screen, in hoping that crashing would stop did all updates from Microsoft
i did updates from MSI updates for BIOS, chipset, drivers
did update from Nvidia for graphics card
i also have done testing on memory using Mem86, passed both short and extended tests
also did tests on hard drive using SeaTools passing all tests too
then started crashing getting blue screen and now after 2 days of not using it planned on starting it up doing a battery of test.
went plugged it in, click start buttom, computer started but shut down and restarted and shut down
computer didnt even make it to the 1st beep
SO MAIN QUESTION IS IT THE PROCESSOR, MOTHERBOARD, MEMORY DONT THINK ITS POWER SUPPLY BOX
if u need the help of blue screen log let Me know will at to it with no problem
thank you
MasterTom
mailto:twistertom@msn.com twistertom@msn.com
A good starting point in troubleshooting your problem is to follow the procedure given by the manufacturer of your board.
"went plugged it in, click start buttom, computer started but shut down and restarted and shut down computer didnt even make it to the 1st beep"
This usually indicates a problem with the power supply. Make sure the connectors are seated and locked. Next, try a different PS. (A better one) Power is most critical of any PC--Don't skimp.
