Processeur
BlacKaviar
Bonjour,
J'ai un Intel® Core™ i7-10750H CPU @ 2.60GH et lorsque je joue à un jeu vidéo style Apex Legends ou Need For Speed Heat la température de celui-ci monte jusqu'à 80°, je ne pense pas que cela sois normal, j'aimerais donc savoir quelle manip je pourrais faire si il y en a ou qu'elle pourrait être le soucis s'il vous plaît ?
AlHill
Your temperature is fine.  Do not worry.
BlacKaviar
And if I have blue screens when I play games it is not related to the temperature please ?
AlHill
Likely not.  Provide a screen photo of the blue screen info or the information/error code on the blue screen.
Also, So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
And, download the IPDT:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
BlacKaviar
Here is the scan
BlacKaviar
And here is pictures of blues screens
AlHill
Seems more likely that you have a memory problem.
BlacKaviar
If you know, can you explain me how to fix it please ?
Jean_Intel
Hello BlacKaviar,
If I may interrupt here. I have found some community forums from Microsoft with suggestions for the Blue Screens of Death, if you want, you can check their suggestions:
However, my recommendation is to contact Acer so they can provide you with more efficient Troubleshooting, as they have more understanding and control over your system. They can also provide me with a hardware inspection and will determine if there is any problem with the memory of your system.
Jean O.
BlacKaviar
Thank you very much, i will check the forums and i will also try to connect Acer hoping for a satisfactory response from them
Jean_Intel
Hello BlacKaviar,
We're glad to know the information helped. Hopefully, it will help other community members. Since you will review the recommendations from the Microsoft forums, also you will contact Acer for further support. We will close the thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
