16848 Discussions
Processor Diagnostic Tool MMXSSE Fail "could not load DetectUtils64.dll" Intel Core I5 8600k
Ave_
Hi, Im gonna try to keep it short while explaining everything as detailed as I can:
I suddenly had problems playing games: they were very laggy and the cpu ussage in the taskmanager was extremely high (even at 100%). Which is pretty unusual since even csgo had these problems even tho I have an  I5 8600k.
I googled and searched the web because I figured other people might have the same problem and tried some weird reg edits and stuff but nothing changed anything, then I came across the Intel Processor Diagnostic Tool and the Test failed:
Test Summary:
--- IPDT64 - Revision: 4.1.4.36
--- IPDT64 - Start Time: 04.01.2020 10:44:36
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Fail.
IPDT64 Failed
--- IPDT64 - End Time: 04.01.2020 10:44:37
FAIL
Cpu1:
--- Genuine Intel Test ---
Version 1.0.16.64b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.20.64b.W
IntelR CoreTM i5-8600K CPU 3.60GHz
Brand String Module Success....
 --- Cache Test ---
 --- Reading Cache Size ---
 - Detected L1 Data Cache Size -- 32
 - Detected L1 Inst Cache Size -- 32
 - Detected L2 Cache Size -- 256
 - Detected L3 Cache Size -- 9216
Cache Module Success
 --- MMXSSE Test ---
Version 1.0.22.64b.W
..could not load DetectUtils64.dll
I ran the system support unit and attached my results.
I hope you can help me.
With regards Ave.
AlHill
Please do not try or resort to "weird reg edits and stuff".
What anti-virus software do you have installed? What firewall?
Are you using any cleaners?
Why are you using windows 10 version 1709 (from more than two years ago)? Update to version 1909.
Doc
Ave_
Thanks for the response!
  1. I thought that maybe it was a well known thing and that there could be an easy solution idk
  2. I deactivated both cause I was already suspecting them to be the problem
  3. I run ccleaner like every two months
  4. Thats something I never noticed thank you! I just tried to manually update it and got Errorcode "0xc1900204" which is probably also the reason why my windows didnt automatically update. Im gonna look into how to get the newest version without losing my programms and stuff tomorrow thx
AlHill
Update your windows from here:
https://www.microsoft.com/en-us/software-download/windows10
Also, stop using cleaners. They can cause more harm than good, and never use the registry cleaner.
Doc
AlHill
Another user just had a similar problem with IPDT, and discovered it was his use of avg and cleaners. I suspect your problem is the same, which means you need to do a clean install of windows, or reset windows, and get rid of those third party virus checkers and tools. Avast/avg/ccleaner are not helping you.
Doc
J80
I had the same issue with the "could not load DetectUtils64.dll" error. Here's what worked for me:
Make sure you are running the Diagnostic Tool from your C: drive (or boot drive, maybe?). I originally installed mine on a secondary disk (D:) and it kept failing half the tests because of the missing .dll. Uninstalled and reinstalled on my boot drive (C:) and no problems!
