16774 Diskussionen
Processor J4205 NOT movies 3DBD ISO
iivan23
Einsteiger
5.410Aufrufe
Why J4205 processor does not work 3DBD ISO ?
System - Windows 10-64.
TotalMedia Theatre 6 and Power DVD 16 is not active 3D mode.
This 3DBD ISO is working on processors N3150 and N3700 very well.
Thank you.
11 Antworten
Mitarbeiter
3.945Aufrufe
Hello ivan2000,
In regard to your concern, after a research, I was able to confirm that your processor Intel® Pentium® Processor J4205 does not support 3D.
You can confirm this detail at the following link with the official specifications from Intel®:
http://ark.intel.com/products/95591/Intel-Pentium-Processor-J4205-2M-Cache-up-to-2_6-GHz Intel® Pentium® Processor J4205
Under Graphics Specifications, you will see: Intel® InTru™ 3D Technology No
Also, I was able to confirm for Power DVD the processor does not meet the minimum requirements for the 3D format, you can confirm the requirements for Power DVD at the following link:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8# q=power+dvd+system+requirements https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8# q=power+dvd+system+requirements
If you would like to confirm why you are not able to run 3D format with your current processor, my recommendation it is to contact the direct developer of the programs:
Technical Support/Program Developer for Totalmedia Theatre: http://www.arcsoft.com/support/technical-assistant.html http://www.arcsoft.com/support/technical-assistant.html
Technical Support/Program Developer for PowerDVD: http://www.cyberlink.com/support/index.html http://www.cyberlink.com/support/index.html
I am looking forward to heard from you.
Kind regards,
Angie
ДДеми
Einsteiger
3.945Aufrufe
But http://ark.intel.com/ru/products/87258/Intel-Celeron-Processor-N3150-2M-Cache-up-to-2_08-GHz Intel® Celeron® Processor N3150 http://ark.intel.com/ru/products/87258/Intel-Celeron-Processor-N3150-2M-Cache-up-to-2_08-GHz doesn't support this technology too, but 3DBD ISO plays with normal 3D Framepacking!!! Problem in the current drivers
iivan23
Einsteiger
3.945Aufrufe
engineers "experts" Intel
you are a very bad experts in processors.
Ordinary users have confirmed that the 3D-ISO is working on J4205 processor.
Simply output 3D-ISO port should be DVI (via HDMI 2.0 does not work).
Study the technical parameters of the processors to be funny.
shame you
Mitarbeiter
3.945Aufrufe
Hello ivan2000,
One important detail that will be useful for you; the DVI might not work due that the bandwidth supported it is limited.
I would like to continue with a research in order to help you, could you please reply with the following information:
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issue Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>
Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</span>Hardware (HW)Brand and Model of the system. Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too? Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in) How much memory [RAM] in the system (see note2 below). Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc <span style="border: none wi...
iivan23
Einsteiger
3.945Aufrufe
it turned out that after a thorough check:
- HDMI - 3D ISO - does not work
- DVI - 3D ISO work, OK ( DVI-through adapter HDMI. )
it is confirmed by many users.
ISO is working on a 3D J4205 processor.
CPU utilization of 50%.
Why in the specification indicates that no processor J4205 - No 3D support?
This deters many buyers.
Mitarbeiter
3.945Aufrufe
Hello ivan2000,
Thanks for your reply.
I will continue with the investigation of your concern.
As soon as I have further details I will reply to you.
Angie
iivan23
Einsteiger
3.945Aufrufe
repeat
Many users use the J4205 processor - HTPC and media player.
Users looking specification, there is no support for 3D, they refuse to purchase.
I ask you to correct specification of the processor J4205 and processor - N3150, N3700, N3050,
and to put this issue at the highest level, that they might know your leadership on this issue.
Set in the specification - InTru™ 3D - YES
Let AMD envy you))))
Mitarbeiter
3.945Aufrufe
Hello ivan2000,
In regard to your concern, we are investigation the scenario with your concern.
In the mean time at the following link, you will be able to confirm the specification for the processors ( J4205, N3150, N3700, N3050):
http://ark.intel.com/compare/87257,87261,87258,95591 http://ark.intel.com/compare/87257,87261,87258,95591
Also, I have added an attachment with the information of the 3D features details.
Could you please provide us with the information or a link where you were able to confirm that those processors support the 3D format?
This information will be really appreciated for our investigation.
Angie
iivan23
Einsteiger
3.945Aufrufe
Hello.
I do not know how you prove.
you can check it on any computer with these processors.
install ArcSoft TotalMedia Theatre software or CyberLink PowerDVD 10.
record the movie in BD3D-ISO and open those programs mentioned above.
you will see that everything works.
I realized that there is no Intel® InTru ™ 3D Technology - hardware support.
you can specify state that Intel® InTru ™ 3D Technology - software is supported.
This greatly helps users to do this.
Mitarbeiter
3.945Aufrufe
Hello ivan2000,
Thank you for all the information provided.
We will work on an extensive investigation in regard to all the details that you have mentioned. As soon as we have further details, we will let you know.
Best regards.
Angie
Mitarbeiter
3.945Aufrufe
Hello ivan2000,
Thank you very much for your feedback, it is really appreciated.
Angie.
Antworten
