Processor State
JGamb1
I cant change my Maximum processor state down to 98% to disable turbo boost because it affects the performance in game giving me fps drops which is not good
Hello, desired215. Thank you very much for taking the time to reach the Intel Communities Team. I will do my best to assist you further.
I would like to know what is the error that you are having that is not letting you change the Maximum processor state to 98%? On the screenshot attached, I can see that this option can be modified. Furthermore, you should be able to disable the Intel® Turbo Boost Technology from the BIOS.
Antony S.
JGamb1
I tried entering in the BIOS but there is no option in turning off the turbo boost. Sadly, it just stays at 100% when i try to type in 98% and click apply it reverts back to 100%.
Thank you very much for your reply, desired215.
In this case, if your BIOS does not show an option to disable either the Intel® Turbo Boost Technology or Intel® Speed Step, I recommend you to get in touch with the manufacturer of your system so they can help you further to disable this feature.
Antony S.
