16785 토론
Processor for LGA775 socket
AGupt25
초급자
4,762 조회수
I have a G41 series motherboard. Is there any Intel processor which is still supported for G41 series m/b (basically LGA775 socket)? If so, where can I buy it in New Delhi pls?
Arvind Gupta
0 포인트
3 응답
AlHill
수퍼 사용자
3,648 조회수
If you are asking about the DG41TY board that went bad, here is a list of compatible processors.
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DG41TY Compatible Processors
For your Gigabyte G41 board, I am certain Gigabyte has a list of compatible processors. Select from those processors only, as those are the ones supported by the gigabyte bios.
Also, make certain your gigabyte g41 bios is at the proper level for the processor you select.
In New Delhi? I have no idea.
Doc
AGupt25
초급자
3,648 조회수
OK. Thanks for the reply. I found a list for processors supported by the gigabyte m/b I intend to buy. The list is https://www.gigabyte.com/Ajax/SupportFunction/GetCpuList/?Value=3505&Type=Product here. my my question is: how many of these are still supported. As I understand, core two/quad series came up long back.
Arvind Gupta.
0 포인트
AlHill
수퍼 사용자
3,648 조회수
None of them are "supported".
Using "yorkfield" as an example, they were all discontinued long ago.
https://ark.intel.com/products/codename/26553/Yorkfield?q=Yorkfield Products formerly Yorkfield
And, if you have Windows 10 as a goal, you should really rethink this whole effort, as none of this will be supported on Windows 10.
Doc
0 포인트
응답
