17531 Discussions
Processor stepping
Qilin
SR2KE, Xeon 2673 v4 processor stepping. Can not find reliable information
AlHill
The CPU supported by your friend's motherboard is E5-2699-v3, not the E5-2673 v4.
https://www.asus.com/support/CPU/1/42/3/2/qCCN4VASDw933uL6/C20140909142535/
As you can see in the above link, you and your friend have problems with your configuration, using an incorrect processor.
Now, stay with your original thread and stop insisting that the processor is the problem.
https://community.intel.com/t5/Processors/Errors-when-starting-the-system-CPU/m-p/1289357#M51927
AlHill
Stop this.   The 2673 is not supported on your board.   Use a supported processor, and get rid of the 2673.
AlHill
So?  If you want to believe some 3rd party site rather than ASUS, be my guest.   And, that site is talking about an X99-A board, not an X99-S board.
What you do not understand is that a processsor, to be supported, must be socket, chipset, and BIOS compatible.
You have been given the answer here.  Now, it is time for you to argue with ASUS.
AlHill
OK, show me where the 2673v4 is in that list.
