16774 Diskussionen
Proper Setup for Core i9 14900KF with ASUS Prime B760-Plus
CapVideo
Einsteiger
4.306Aufrufe
I am experiencing multiple program crashes (crashes to desktop) with my new build PC (mid-January) and this combination of processor and MoBo.  The crashes are occurring not only with a major game/simulation (MSFS 2020) but a number of other programs such as Thunderbird E-mail, Mozilla Firefox, Adobe Acrobat, etc.  The system ran well for about 3 months, then the crashes started up.
According to my PC builder, the BIOS was set to default at installation.  Numerous tests were run for possible issues:
1) Ran all Windows updates - everything is up-to-date.
2) Ran malware scans and antivirus scans - clean
3) Ran Dism series - clean
4) Ran sfc /scannow - no integrity violations.
5) Ran memtest86 - no issues with RAM
5) Did a complete uninstall/reinstall of MSFS 2020
6) Did a complete Windows 10 In-place Upgrade! Everything went well but everything is still failing as before.
After seeing a number of recent articles on this processor being overclocked by MoBo manufacturers default settings and causing game crashes, I downloaded and flashed the BIOS with the latest ASUS version to attempt to rectify this issue (ver. 1656).  This version includes the new Intel Baseline Profile option which is supposed to rectify this situation.  This did not work - when I activate the option nothing happens and no changes are made.
I am a multi-decade experienced user as far as Windows OS and hardware, though I have never overclocked any of my systems nor have I worked with modern processors and BIOS settings. I really need some help here as this PC is basically useless for me, and I fear that the Intel processor may also have been damaged by ASUS "default" settings. Using NZXTCam for statistics, it currently shows the CPU Default Clock Speed as 3200 MHz - the Current Clock Speed is varying up to 6000 MHz.
5 Antworten
mdawe
Einsteiger
4.270Aufrufe
So I was in a very similar situation to you (almost exactly). The only additional item was I paid a local shop to do a bench test on the processor and confirmed the stability problems carried over. I then RMA'd the chip but mine was exposed to the situation for a year before stability issues occurred.
CapVideo
Einsteiger
4.244Aufrufe
It's become obvious that I'm not the only one dealing with this.  I should note that I was finally able to make the 'Intel Baseline Profile' option operational.  I had to first reset the BIOS to 'Optimize to Defaults', THEN set the Baseline option.
It appeared that only a couple of changes occurred (apparently voltages?) but the end result was the same - all of the same apps are crashing or malfunctioning in the same manner, but that's probably due to the instability of the CPU.
My builder has just notified me that the CPU replacement has arrived, so fingers crossed.
CapVideo
Einsteiger
4.196Aufrufe
OK - my new CPU is in place (exchanged by Intel under warranty) and I'm finally operating normally again (after 2 weeks of terror).  MSFS and all of the programs that were crashing have been stable.
I am continuing to run the 'Intel Baseline Profile' in the BIOS (v.1656), as it's the only way that I can over-ride the "optimized defaults" without a lot of tweaking.  I'm going to hold off on running XMP for now - if the system is still stable a month from now I'll transition to Win11.  If that runs well for a couple of months I'll reset with XMP.
Standa1
Einsteiger
2.205Aufrufe
Hi @CapVideo ,
I'm currently going through the same / very similar issues with same CPU+MBO ...  now for 2 weeks back RMA with supplier ( luckily bought it as whole PC - no longer building it up myself ) ... already on Win11 from the start ... and just became unusable after approx 6months > CPU temp. almost immediately shooting up over 80 just after boot-up  > even when in BIOS editing mode only ...
Now I'm wondering ... if ... (i'm expecting) they exchange CPU  (for the same model / make) ... how did it work for you after ?
Are you still in the BIOS 'Intel Baseline Profile' ?
Even though Intel is recommending * using the Extreme setup for the 14900KF ... I'm also thinking that I'd rather run on less % of CPU's power ability ... rather than dealing with the same issues 6 months later ?
Not sure if the A's & W's in BIOS are then "tuning it down"  to just about 62% of the CPU's power !? ... ( as baseline being 249A of extreme 400A  ... or ... the P1 ...baseline 125W of 253W extreme ? ) ... is it really running only on 50-60% of it's CPU potential ?
Did we just spend fortune on faulty HW ... that should have been cheaper AMD with same'ish power no issues ?
5
CapVideo
Einsteiger
2.079Aufrufe
My apologies for the delay in my response.  Your request arrived during a difficult schedule and this is my first opening.
All is running well with the replacement from Intel.  I am no longer running the Intel Baseline Profile, as the new BIOS (which I downloaded from ASUS) is performing well.  This latest BIOS was touted as containing all of the adjustments from Intel that are appropriate for this series.  I have never been a fan of overclocking, especially with the power of modern processors, and the recommendations of most users for similar software that I am running is that the default setting with the new BIOS is appropriate.
I also downloaded and updated the chipset from Intel.
It is my understanding that we are in the window where Intel will still replace your processor, but that it's a one-off.  They're not going to do it twice.  I would get a replacement ASAP and make sure the BIOS is the latest.
I am still running Win10, but now that everything appears to be stable I am preparing to transition to Win11.
Antworten
