17514 Discussions
Question regarding faulty processor
AWar
I've been going through a lengthy troubleshooting process with a computer I've been building and I'm trying to narrow down all possibilities. My issue is that when I go to power up the system, it powers up for about a second and then shuts down. In the short time it is powered, the debug led display shows 00(failure to post). I had already RMA'd my motherboard thinking this was the issue but after receiving a replacement I'm still having the same problem as before.
Now while it is possible that I've gotten yet another dud mobo, there is one thing that I cannot seem to find an answer on. On the motherboard, the standby LED does not light on when the PSU is flipped on. Can a faulty processor prevent this light from turning on at all? If it can, I think I will be trying to replace the processor next.
Here's all of the things I've tried to resolve this issue to no avail:
Attempted to power up with bare minimum component
Attempted to power up testing the RAM sticks one by one
Shorted the CMOS battery to clear the BIOS
Attempted to power up with components outside of the case
Tested the PSU rails with a multimeter to confirm that the proper voltage was being given
Hooked up PSU to separate system to confirm it works
Attempted to power up system with a separate but known to be reliable PSU
Confirmed that switches were not faulty on case
Specs are below
Main Board: MSI Gaming 5
CPU: Intel 4790k
Bios Version: N/A
Video Card: Gigabtye GTX 980
PSU:Newton R3 FD-PSU-NT3W-1000W
Memory: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 2133 Model F3-2133C11D-16GXL
SSD/ HDD: Samsung 850
Any help would be greatly appreciated.
Kevin_M_Intel
Hello Awoogawar,
Here you have some other troubleshooting steps to try:
  1. Even though you have replaced the memory, make sure it is running at the supported speed for the processor (1600MHz).
  2. If possible try another processor on the motherboard.
It is important to say that some motherboards show a red LED when the processor is not working so that depends on the motherboard design.
All troubleshooting steps you have done are very good so try the above and if you are still having problems, contact our support center:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Kevin M
AWar
I don't think it will be possible for me to get the memory running at the supported speed first hand as I don't have another computer to install it and detune it. However, my understanding is that this shouldn't be an issue for booting up but more so stability issues if I could ever get it to post. I'm also in a location where access to parts is by order online only so at this stage I feel like I've exhausted all my options.
I do appreciate the answer about the stand by LED but I'm completely perplexed as to why or even how I'd get two motherboards exhibiting the same problem. From most likely to least right now I'd say it's the processor, the mobo (again) or the PSU. The PSU is the wildcard because the rails were giving the correct voltage but unless there's something I'm overlooking I'm not sure how it'd be leading to a 00 code.
I'll give it a go with the online support later. Otherwise, thanks for the help.
Kevin_M_Intel
