16766 Discussões
Random Freezes - Intel Core i5-6600 CPU @ 3.30GHz, 3301 MHz, 4 Cores
DDiet1
Principiante
3.912 Visualizações
Hello everyone,
my computer freezes randomly, from 144p videos to 1080p ones, from flashgames to high end games, even when the computer is idling to long. Have this problem now for months and searched severfal forums but didn't find any solution. Im in desperate need of help.
Sound freezes in some kind of weird loud loop or completely silent.
Computer freezes, cant use mouse/keboard or other hardware.
The freezes require a hard reset.
Sometimes the computer doesn't freeze at all, sometimes a few times within a few hours.
System Information
Operating System: Windows 10 Pro 64-bit (10.0, Build 10586) (10586.th2_release_sec.161024-1825)
Processor: Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz (4 CPUs), ~3.3GHz
Memory: 16384MB RAM
Display Devices
Card name: NVIDIA GeForce GTX 970
Display Memory: 12211 MB
Dedicated Memory: 4059 MB
Shared Memory: 8151 MB
All drivers should be up to date.
Can't find any event logs after a crash.
Tried "IntelProcessor Diagnostic Tool 64bit" with the following result:
--- IPDT64 - Revision: 4.0.0.29
--- IPDT64 - Start Time: 07.02.2017 21:59:10
CPU1
Intel(R) spbc Module Test
Module Version: 1.0.8.64b.W
Start Time: Tue Feb 7 21:59:10 2017
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz
End Time: Tue Feb 7 21:59:10 2017
Total Time: seconds: 0
CPU1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
CPU1
CPU Brand String Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Floating Point Test
Module Version: 1.0.11.64b.W
AVX is supported in your OS
Max AVX supported = AVX2
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 286.26
Error: 0
--- Floating Point Test Passed!!!---
End Time: Tue Feb 7 21:59:12 2017
Total Time: seconds: 2
CPU1
Prime Number Generation Test
Module Version: 1.0.13.64b.W
Start Time: Tue Feb 7 21:59:12 2017
Test Result - PASS
Operation Per Second: 150385
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Tue Feb 7 21:59:14 2017
CPU1
Cache Test
Start Time: Tue Feb 7 21:59:14 2017
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU...
7 Respostas
Funcionário
2.079 Visualizações
Hello Mornin:
Thank you very much for letting us know that information and for providing those files.
The processor has onboard graphics, based on that, do you have the option to test the PC without the video card?
This is just to rule out a possible problem with it.
Did you try a BIOS update on the motherboard to the latest version 3016? Here is the link in case you want to try that:
https://www.asus.com/Motherboards/H170-PRO-GAMING/HelpDesk_Download/ https://www.asus.com/Motherboards/H170-PRO-GAMING/HelpDesk_Download/
Did you test it just with one memory stick at the time with all the sticks?
This is just to rule out a possible problem with one of the sticks, even though according to the test it seems to be working fine, it is a pretty good troubleshoot to try.
Do you have the option to use a different hard drive/SSD?
Same thing, when the PC is getting freeze, the problem could also be related to the hard drive/SSD itself.
Are you doing overclocking on the processor?
Any further questions, please let me know.
Alberto
DDiet1
Principiante
2.079 Visualizações
Thanks for the reply and suggestions!
- The processor has onboard graphics, based on that, do you have the option to test the PC without the video card?
Tried with a different GTX 970, same issues.
- Did you try a BIOS update on the motherboard to the latest version 3016?
Maybe I'll try this, have to read a tutorial or contact some expert on how to update my BIOS.
- Did you test it just with one memory stick at the time with all the sticks?
- This is just to rule out a possible problem with one of the sticks, even though according to the test it seems to be working fine, it is a pretty good troubleshoot to try.
Memory sticks work fine, tried with another identical memory stick - still freezes - and let a memtest run over night without issues.
- Do you have the option to use a different hard drive/SSD?
Tried with my old hard drive - same issues.
- Are you doing overclocking on the processor?
Will check again but I'm pretty sure I don't.
Had two freezes yesterday, none today.
Funcionário
2.079 Visualizações
Hello Mornin:
You are welcome.
Thank you very much for letting us know that information.
You mentioned you test it with a different video card, but do you have the option to test it without any video card, just using the onboard graphics?
The BIOS update to the latest version is always a good option to try, specially if you are using Windows® 10, so if you can please try that will be really helpful.
To get the information about how to do it, please get in contact with ASUS directly:
ASUS's phone number: 1-888-678-3688
ASUS's support site: https://www.asus.com/us/support/ https://www.asus.com/us/support/
Please let me know the results of trying the steps above, and if you can verify if the processor is being overclock that will be very helpful.
Alberto
DDiet1
Principiante
2.079 Visualizações
Again, thanks
- The BIOS update to the latest version is always a good option to try, specially if you are using Windows® 10, so if you can please try that will be really helpful.
Updated my BIOS. Let's see.
- Please let me know the results of trying the steps above, and if you can verify if the processor is being overclock that will be very helpful.
Processor is not being overclocked.
- You mentioned you test it with a different video card, but do you have the option to test it without any video card, just using the onboard graphics?
Thing is I would have to run the computer a few days with just onboard to see if it freezes. Will look into this if freezes remain.
Only one freeze the last two days.
Edit: If I don't reply or edit this post the next few days I declare this problem as fixed. Hopefully it is..
DDiet1
Principiante
2.079 Visualizações
Problem still remains.
Funcionário
2.079 Visualizações
Hello Mornin:
We are sorry to hear the problem remains.
At this point, the next thing to do will to swap parts because the problem could be related to the motherboard or processor.
Based on that, do you have the option to use your processor on a different board, or your board with a different processor?
By doing that we can make sure about the source of the problem, which normally is related to the board.
Alberto
Funcionário
2.079 Visualizações
Hello Mornin:
I just wanted to check if you were able to try the steps above and if the problem still persists or if it was resolved?
Alberto
Responder
