17248 Discussions
Rendering problem on Intel Core i9 12900KF CPU
Three_D
Hello
We've changed our company CPU to intel Core i9 12900KF (16C ,24T) and the th PC is used mainly for 3DS MAX and Corona renderer . the problem is while rendering the task manager shows that only 8 threads are used from the 24 , and the overall usage at 40%.
we've updated the Bios and all drivers
the OS is windows 10
64G RAM
n_scott_pearson
Unless I don't understand your query, you are talking about graphics rendering operations. These kinds of operations are actually going to be performed mostly by the iGFX engine. It's somewhat interesting that it is taking 8 threads to support the feed of these operations in to and out of the iGFX engine (I would have guessed less).
Three_D
thanks for the feedback ,
I should have noted that Corona for 3DSMAX   depend heavily on CPU thread count and normally takes all the processer's power
also i've tried to benchmark using cinabench it used 100% of the CPU .
thanks
DeividA_Intel
Hello Three_D,
Thank you for posting on the Intel® communities. I understand you are having issues with your Intel® Core™ i9-12900KF.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Provide the report from the Intel® Processor Diagnostic Tool:
3. Did the app work as expected before or with another CPU? If it worked with another CPU, can you provide the brand and model name?
4. Can you provide the name and version of the tool that you are using?
5. Did you notice this issue with other apps? If so, which apps?
Deivid A.
DeividA_Intel
Hello Three_D,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Coody
Hi,David
how do I know that all my choirs are running if they show me 8-16 in the task manager?? I have windows 10
DeividA_Intel
Hello Three_D,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
tanjamin
for 100% CPU usage during 3DsMax rendering, Set :ACTIVE EFFICIENT CORES" value to 0 from bios.
