16774 Diskussionen
SMD elements prosessor G3930
Captain_Jack
Einsteiger
2.801Aufrufe
Hello, how can I find out the smd values ​​of the elements located at the bottom of the G3930 processor? Is there such documentation? Thanks.
8 Antworten
DeividA_Intel
Mitarbeiter
2.777Aufrufe
Hello Captain_Jack,
1. Can you explain what does "SMD" stands for? We got several matches.
2. Why are you needing this information?
3. Are you developing any software or hardware?
Deivid A.
Captain_Jack
Einsteiger
2.766Aufrufe
Yes, periodically to repair damaged processors
n_scott_pearson
Superuser
2.773Aufrufe
I think he is referring to the values of the Surface-Mount Devices (SMDs - capacitors, resistors, etc.) that are on the bottom of the drive - presumably to repair a damaged processor.
I believe that Intel considers this IP and does not give out this information.
…S
Captain_Jack
Einsteiger
2.766Aufrufe
DeividA_Intel
Mitarbeiter
2.753Aufrufe
Hello Captain_Jack,
Thank you for the information provided
Deivid A.
Captain_Jack
Einsteiger
2.745Aufrufe
Thank you, dear friend: I will be glad if it works out
Captain_Jack
Einsteiger
2.743Aufrufe
DeividA_Intel
Mitarbeiter
2.725Aufrufe
Hello Captain_Jack,
Thanks for the information provided so far,
In this case, I would like to let you know that we do not have support for manually altering or repairing a processor. We do not have any documentation with this information either.
If the processor gets damaged, the best would be to replace it through the place of purchase or with us if stills under warranty.
Deivid A.
Antworten
