16841 Discussions
SSE: addps seems to treat integer data
JRICH21
Hello everybody,
I asked my students to work on a programming project using SSE registers to
compute fibonacci numbers. I asked them to use integers but some of them used
instructions that are supposed to treat floating-point data.
Here is a simple example in NASM that loads integer data using floating point
instruction and then performs what is supposed to be a floating-point addition
but when I display the result I get integers : 1, 3, 5, 7
a: dd 0, 1, 2, 3
b: dd 1, 2, 3, 4
msg: db "%d %d %d %d", 10, 0
section .text
main:
push ebp
mov ebp,esp
movups xmm0, [a]
movups xmm1, [b]
addps xmm0, xmm1
My question is how is it possible or am I missing something ?
If anyone has an answer I would be very interesting to have an explanation
it seems strange to me.
resgards,
Jean-Michel
Adolfo_S_Intel2
In this particular case, I would suggest contacting a Field Application Engineer (FAE) so they can assist you with your inquire.
In order to contact a Field Application Engineer (FAE), please call any Authorized Intel® Distributor on your location and ask them to put you in contact with a FAE.
You can find a list of Authorized Intel® Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
If you are outside the United States, please access the following link and select a location, to find the closest authorized distributor:
http://premierlocator.intel.com/Default.aspx http://premierlocator.intel.com/Default.aspx
JRICH21
Thank you for your answer, I will try to contact a FAE.
I have found part of the anwser in the following documentation
64-ia-32-architectures-software-developer-vol-1-2a-2b-3a-3b-manual.pdf (4060 pages)
where it said that there is a "numeric interpretations of fundamental types for use in packed integer
and packed floating-point operations".
However I don't know you the distinction is made between integers and floating-point values.
Although floating point values use the IEEE 754 representation, there are integers that correspond
to representations of FP values. For example :
the float value 1.5
is coded 0x3FC00000 in IEEE 754 (32 bits)
but also corresponds to the integer value 1069547520 (32 bits)
JRICH21
I found some explanation in the documentation of
where it is said that there is a "numeric interpretation of fundamental types for use in packed
integer and packed floating-point operations"
The main question is now : how is it possible to distinguish in 32 bits integer from floating
point (FP) data ?
For example :
1.5 has an IEEE 754 representation of 0x3FC00000 in 32 bits
but this also corresponds to the integer value 1069547520
so if the exponent part of the 32 bits in IEEE 754 representation is 0
then we could say this is an integer value, but in other cases it is not
possible to distinguish between integer or FP
