16840 Discussions
Seems im affected?
Steven11111
I bought an i5 14600kf processor a month ago. Ever since assembly, the system hangs and points to gpu hardware fatal error. This is with the Palit 4080 Super card. The card supplier has swapped the card out twice and has no resorted to a refund as the issue remains.
I've read about the oxidation issue and the symptoms of the problem, and see gpu related errors is a part of what people are seeing.
Am I affected by this issue? I find it hard to believe both gpus were bad out of box. What happens now?
Senkuchan
Valued Contributor II
Try updating your bios and set your settings to intel default. If the issue is the same, there’s a chance that you’re affected
Steven11111
Yes, tried all of that already. I noticed before doing the f11b(gigabyte) voltage in the bios was at 1.5v, which I believe is too high. After bios voltage dropped to 1.3. Hangs continue though.
Senkuchan
If the issue is the same, you can request a replacement
Steven11111
