17259 Discussions
Severe Lag when opening Performance TAB in Task manager!
Cerisettex
Hello, owner of ASUS ROG Scar 16 275HX RTX 5090 here.
Like some previous posts , I'm experiencing massive lag when opening Task manager and clicking on Performance Tab, it would cause massive lag of 3-4 sec before it opens it.
THIS should NOT happen on such high end machine, even my laptop from 2021 with i7 11800H opens Task Manager immediatly. It's very frustrating to have paid 5000€ on laptop which struggles to open task manager. Mind blowing.
This issue wasn't present with OEM driver 32.0.101.6790 from Windows Update. Windows Update really forcing this 32.0.101.6790 to be installed and reverts back my new driver update with 32.0.101.8331. The fix was to install 32.0.101.8331 without clicking on "Clean Installation" so I can have new Intel driver. Or using utility to block Windows Update 32.0.101.6790.
What I found :
No lags :
OEM 32.0.101.6790 + windows 11 ISO clean installation from USB version October 5th 2025 (and no latest updates from windows update). No lag, instant opening! HOWEVER 32.0.101.8331 (or 8250) + windows 11 ISO october 2025 (no updates) LAGS when clicking on performance tab.
Lags :
1) OEM 32.0.101.6790 + latest windows 11 updates december 2025 (no preview KB5070311) = now even the opening of Task manager lags and not loading it fully but like half , right side is visble with apps and the left side is blank. But it loads after 1-2sec. Almost No lags when clicking on Performance tab (still lags can happen !)
2) 32.0.101.8331 + latest windows 11 updates december 2025 (no preview KB5070311), Task manager opens instantly, but when I click on Performance tab , HUGE lag 3sec. When Im using iGPU only (5090 is off and not appearing in task manager), clicking on Performance tab is slightly faster maybe 2sec.
Major discovery:
I noticed one thing and it might be the key of these lags, upon opening Task manager, all apps icon (small logos) ARE NOT LOADED, they are blank, a soon as apps icons are loaded and displayed , I can click on performance tab and NO LAGS!
This is outrageous it feels like Im not the owner of the laptop and it belongs either to Intel or Asus because Im forced to use old drivers from april 2025, this shouldnt be the case. Thankfully I got rid of all telemetry + local account.
I believe It's Intel drivers + maybe windows 11 updates.
I did 6 times windows 11 iso clean installation, issue is still present! Laptop works flawlessly outside of that Task manager lag !
https://rog.asus.com/laptops/rog-strix/rog-strix-scar-16-2025/helpdesk_download/
Cerisettex
More findings :
Upon DDU uninstall of Intel driver  32.0.101.8331 + Nvidia 591.44 in safe mode using DDU, Task manager would open INSTANTLY with no lags! But once I install  32.0.101.8331 or any other (except 6790) it would immediatly lag when opening Task manager and apps icons aren't loaded instantly. It's like Intel driver doesnt give enough power to load, my feelings. I could be wrong Im no engineer.
One thing really drives me mad, after clean DDU and installing latest  32.0.101.8331, Windows would force by itself the old april 2025  32.0.101.6790 driver ! OMG !!! WHY? WHY? WHY? I can't wrap my mind. Can't revert back to  32.0.101.8331in Device manager.
So I have intall it again on top of  32.0.101.6790 and this making DDU useless!
Intel please fix it!
JohnM_Intel
Hello Cerissetex,
Thank you for providing such a detailed description of the issue with your ASUS ROG Scar 16 (275HX, RTX 5090). I completely understand how frustrating this must be especially on a high-end laptop where opening Task Manager and the Performance tab should be instant. I really appreciate the time you’ve taken to test different driver versions and Windows updates; the information you’ve shared is very helpful.
From what you’ve described, it seems the lag is related to how certain Intel driver versions (32.0.101.8331 / 8250) interact with Windows 11 updates, while the older OEM driver (32.0.101.6790) does not show the same problem. Your observation about the app icons loading delay in Task Manager is a great insight and could explain why the Performance tab lags.
To help narrow this down further, I’d suggest:
  1. Testing OEM vs. Intel drivers: Compare the older OEM driver (32.0.101.6790) with the newer Intel driver (32.0.101.8331) to see if the lag consistently happens with the newer driver.
  2. iGPU vs. dGPU: Since you noticed slightly less lag when using only the iGPU, testing with both GPU setups could give more clarity.
Thanks again for your patience and for sharing all the details it really helps.
John M.
Cerisettex
hello JohnM_Intel
Thank you very much for your message. Much appreciated.
I did DDU of both Intel and Nvidia GPU. I downloaded from ASUS G635LX https://rog.asus.com/laptops/rog-strix/rog-strix-scar-16-2025/helpdesk_download/ the OEM Intel driver 32.0.101.6790. Then I installed. But windows still force it's own 32.0.101.6790 on top of my already installed  32.0.101.6790. Very strange.
It doesn't happen with Nvidia. I also installed latest KB5072033 on December 9th 2025.
Then I used Chris Utility debloat tool (even though my Windows 11 iso is already "pre debloated" meaning I forced local account instead of microsoft and no tracking). My process in task manager went from 200 to 150. And now I can open instantly Task manager for some reason. This is on 7 day old Windows 11 with literally no software installed as I use this laptop only for 2 games. So it's a very clean device.
Why this happens and why I can't install latest Intel driver?
By the way with  32.0.101.6790, upon switching in Armory Crate from Nvidia GPU only to Optimus (advanced) and then rapidly to eco-mode to have iGPU only , I got BSOD "critical process died". It did not happen with 32.0.101.8331 / 8250 or it could be a coincidence.
Is my motherboard dying or is it drive issue when switching to igpu rapidly? I think driver issue since 32.0.101.6790 is so old I dont see why I should use it.
Thank you
SBoy2007
I tried your method on the driver of 8331,unfortunately it doesn't work,the task manager is still severe lagging on my computer.
Cerisettex
Hi man,
You didnt follow well my guide. Make sure you have latest bios , 327 for SCAR 16/18
1) Clean windows 11 installation with rufus and pre-injected local account inside ISO (rufus) no online account !!. You can install now just dont format, install on top of SSD with your current windows 11 it will create a folder windows.old and you can restore all your files but you will have a completely clean windows without any bloatware apps. With Rufus create local account, remove data telemetry, 4Gb RAM requirements.. Prepare notepad file with Chris Utility Tool command
2) During windows 11 installation do not connect on internet. skip that part.
3) once in windows, Install intel ROG 6790, restart
4) set password (its mandatory will be asked)
5) Install Nvidia latest GPU driver
3)Once in windows 11, open notepad with Chris Utility tool command. Copy it. Right clic on Windows start logo, select Terminal Admin. launch Chris utility tool
6) Standard tweaks, RUN (restart and activate Windows Defender back)
7) Install all updates from Windows Update
Install DirectX (techpowerup)
9) Install all redistributables (pack from techpowerup)
10) Install all .NET from 5 to 10
11) Launch Chris Utility Tool, Standard Tweaks , and Disable Windows Platform Binary TABLE (WPBT) and
Restard and activate Windows Defender.
I have 0 lags now ! Lags only happended in Standard GPU, Optimus.  No lags in GPU eco mode, or Ultimate GPU
Cerisettex
Dear JohnM_Intel.
Thank you for your answer.
I did managed to fix this bug. I will explain how.
1) I used OEM Intel driver 32.0.101.6790 from Asus G635LX page. But strangely Windows Update force it's own 32.0.101.6790 although it's already installed, it installed on top of the same! It doesnt happen with Nvidia drivers.
2) My windows 11 is clean, meaning I used rufus to make a bootable ISO and I removed all tracking and requirements, and I pre-made local account with my own name. This ISO was used to install my current Windows 11. No additional software were installed, it's only laptop for gaming. My process in Task mananger is 190-200. Which is excellent and not much. It's a very clean Windows 11!
3) Yesterday on December 9th 2025, I installed latest KB5072033 through Windows Update. At this stage Task manager did not opened instantly!
4) I used Chris Utility Tool , I clicked on recommended Tweaks. My process went from 190-200 to 150-160! Incredible.
And after rebooting Windows , Task Manager opens instanlty! Finally! I havent tested with 32.0.101.8331 / 8250 yet.
However I want ask question with 32.0.101.6790 when I switched from Nvidia GPU only to Optimus (advanced) then to iGPU only with Armoury Crate Asus, I had BSOD Critical Process Died  (it was before Chris Utility tool so it has nothing to do with it). I had some apps open. Is it because of driver 32.0.101.6790 , since it's old? Only happened when I switched to iGPU only rapidly.
RandyT_Intel
Hello Cerissetex,
Thank you for the detailed update and for sharing your solution!
I'm responding on behalf of my colleague John. It's great to hear that your initial concern regarding Task Manager's slow opening has been completely resolved through your systematic troubleshooting approach using the OEM Intel driver and Chris Utility Tool optimizations.
Regarding your additional question about the BSOD "Critical Process Died" error that occurred when switching GPU modes with driver version 32.0.101.6790 - I believe it would be best to submit this as a separate support thread for proper investigation.
I'm unable to provide specific commentary on this BSOD issue at this time because I would need to:
  • Validate the complete BSOD error message and dump files
  • Determine whether this is a hardware-related issue or driver compatibility problem
  • Analyze the specific circumstances around the GPU switching process
A dedicated thread for this BSOD concern would allow for thorough investigation with proper diagnostic steps and ensure you receive the most accurate assistance.
Thank you for your patience, and congratulations on resolving the primary Task Manager issue!
Randy T.
Cerisettex
Thank you !
No problem.
I think I found the main issue.
Both "Only Nvidia GPU (5090)" and "Only iGPU (intel integrated graphics") do not have bug when opening Task Manger with 32.0.101.6790 and Windows 11 with latest KB5072033.
The Bug (freezing) only happens in Optimus (advanced Optimus, when laptop can choose from Integrated Intel graphics or RTX 5090). The icons (in task manager, softwares) do not load quickly, so this makes a huge lag in Task manager. Only when either iGPU only or GPU 5090 only selected, it doesnt have a lag.
I have no idea what's the main cause of it, is it Intel Chipset or something related to Advanced Optimus.
(My BSOD was from old drivers 32.0.101.6790 and rapid switching from 5090 to igpu only).
JohnM_Intel
Hello Cerissetex,
Thank you for the update, and I appreciate you sharing your findings. It’s great that you were able to identify when the issue occurs and narrow it down to Optimus/Advanced Optimus mode.
Is there anything else you need assistance with or any additional behavior you’ve noticed that you’d like us to look into? I’m here to help if needed. If there are no further concerns, please let me know so we can proceed with closing this thread.
John M.
JohnM_Intel
Hello Cerissetex,
I wanted to check if you had the chance to review the questions I posted. Please let know at your earliest convenience so that we can determine the best come course of action to resolve this matter.
John M.
Cerisettex
Nothing to report. You may proceed with closing the thread.
JohnM_Intel
Hello Cerissetex,
Thank you for confirming that there is nothing further to report regarding this concern and for letting me know that I can proceed with closing this thread.
I will go ahead and close it now. Should you encounter any issues in the future, please feel free to post them on the community threads.
John M.
