17158 Discussions
Slow command.com launching on i5-4570
MPine1
I have a lot of Dell Optiplex 3010 with 3rd Generation i5-3470 Win 7 Pro 32-Bit. On those PCs I can launch command.com with no problem. Now the Optiplex 3010 have been reeplaced with Optiplex 3020 with 4rth Gen i5-4570, but now on this new model the command.com have a 5-10 second launching delay. This is a bad issue, because my app get this delay every time for each transaction. I found a similar issue here: https://communities.intel.com/thread/51161 https://communities.intel.com/thread/51161 http://www.intel.com/support/processors/corei5/sb/CS-032468.htm http://www.intel.com/support/processors/corei5/sb/CS-032468.htm http://ark.intel.com/es/compare/68316,75043 http://ark.intel.com/es/compare/68316,75043 It seems like 4th generation processor are not ready to support old commands, like command.com. Can you confirm that, and maybe a solution. Thanks.
Jose_H_Intel1
Hi, this issue was explained in the thread and article you linked above.
At this moment there is no workaround.
I am really sorry for the inconvenience.
