Any way, other than third party tools, to stop Intel Turbo Boost Max Technology 3.0 from loading an icon in the Windows 7 x64 Notification Area?
I don't want to uninstall the application or driver, and preventing the service from loading at startup has no effect on the Notification Area icon.
链接已复制
Hello raymondjpg:
As an option depending on the PC that you are using, if you can access the BIOS, there might be an option to disable turbo boost, you can try that, the icon on the notification area should disappear.
Or another option will be to customize the notification area by choosing which icons will appear or not in there, on the following link you will find the steps to do that, please scroll down until you see the instructions for Windows® 7:
http://www.howtogeek.com/75510/beginner-how-to-customize-and-tweak-your-system-tray-icons-in-windows-7/ http://www.howtogeek.com/75510/beginner-how-to-customize-and-tweak-your-system-tray-icons-in-windows-7/
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Also, you can always contact Microsoft to verify if there might be another option to manage or customize the notification area:
Microsoft's phone number: 1 800-642-7676
Microsoft's support site: https://support.microsoft.com/en-us https://support.microsoft.com/en-us
Alberto
Thanks but disabling turbo boost in the bios would disable Intel Turbo CPU clock multiplier to 35x over stock 30x, and it is not turbo boost I want to disable.
I want to stop the Turbo Boost Max icon, for one core, from loading in the system tray.
It also appears that Microsoft is powerless to hide some program icons in the notification area, effectively hijacking it. Intel Turbo Boost Max appears to be one of these.
I have found that I can disable the executable ITBM.exe, but that is a sledgehammer approach. Better if Intel could provide an option to not show the Turbo Boost Max icon in the notification area in the first place, and some other way of opening the application..
Hello raymondjpg:
Thank you very much for letting us know that information.
We will take your suggestion under consideration, and I will send it to the proper department so they can get your feedback.
From our side, at this point the options above will be the things to try in order to hide the icon, this scenario is basically related to Windows itself, so to get a different work around, if that is possible, Microsoft should be able to provide further details about that.
Alberto
