16769 Discussions
Support of Intel® Q670 Chipset
Narita
Débutant
558 Visites
If you check the URL below, you will see that the "Intel(R) Q670 chipset"
supports the 12th generation Intel® Core™ processor family.
Intel® Q670 Chipset and Intel® Core™ Processors Product Brief
We have received an inquiry about whether there are any security issues with the 14th generation CPU,
so could you please confirm this?
0 Compliments
3 Réponses
pressed_for_time
Précieux contributeur II
519 Visites
I run a 14th gen system and using the latest Intel Converged Security and Management Engine Version Detection Tool (CSME) confirms that no security vulnerabilities are present. The system has been updated to the latest 0x12F CPU microcode through a BIOS update and also to the most recent Intel Management Engine firmware. For this particular platform it is version 16.1.35.2557. The latest Management Engine Interface and chipset drivers are also present.
Most Q670 board manufacturers should by now have issued updated BIOS and firmware releases to the same level. Provided systems are updated to the latest BIOS, firmware and drivers there should be no security issue with any of the supported 12th to 14th gen CPUs.
0 Compliments
Narita
Débutant
406 Visites
0 Compliments
VARADHARAJAN
465 Visites
@Narita
For l non processors, latest microcode is  0x3a.
0 Compliments
Répondre
