16835 Discussions
TLB entries, page faults and cached paging structures
I have a few questions on which I was not able to find consistent answers in the Intel specs and/or on the web.
It would be great if someone could help me out with them:
- in general a TLB entry is created after a successful address translation. however, does this also happen if the resulting memory
is not accessible due to access protections (=> page fault)? I mean: the address translation itself worked properly ...
- is an existing TLB entry invalidated if a page fault occurs for that address? Is there different behavior for a) no memory mapped
or b) an access protection occurs ?
- besides the TLB entries: are the PDE/PTEs also stored (as regular data) in the L1/L2/LLC Caches? Or is there an additional cache
for the paging structures?
- if so: are there any circumstances under which the MMU flushes already cached PDE/PTE entries from the L1/L2/LLC caches?
Thanks a lot for your help in advance ...
cw
If you are interested in obtaining this information, we would recommend you to contact a Field Application Engineer (FAE) at one of our distributors.
A list of our distributors can be found at the following web site:
http://locate.intel.com/ http://locate.intel.com/
Once you get to this site, select the country, your location and you will receive a list of our distributors to find one that is located in your area.
