16851 Discussions
Temperaturas del i7 950
Tengo un i7 950 y cuando lo someto al text Linx la temeratura de la CPU total me alcanza los 78 grados y los cores oscilan entre los 85 y 90.
¿Es esto normal otengo un problema de refrigeracion?
Me gustaría hacer OC pero con estas temperaturas no me atrevo.
Salem_W_Intel1
As far as I undestand the temperature of your Intel(R) Core(TM) i7-950 Processor is reaching 85-90ºC; if so, I confirm this is overheating, as the maximum should be 67.9°C; see this indicated under the "Package Specifications" http://ark.intel.com/Product.aspx?id=37150&code=Intel%C2%AE+Core%E2%84%A2+i7-950+Processor+%288M+Cache%2c+3.06+GHz%2c+4.80+GT/s+Intel%C2%AE+QPI%29 here. So, I'd recommend following the suggestions found here:
http://www.intel.com/support/processors/sb/CS-029427.htm http://www.intel.com/support/processors/sb/CS-029427.htm
