16764 Discusiones
The problem of "System May Experience Inability to Boot or May Cease Operation" was made public in Baytrail and Apollolake, but is not Braswell involved?
泰竹村
Principiante
3.583 Vistas
In Baytrail and Apollolake, the problem of "System does not start up or there is a possibility that operation may stop" has been published in Spec update.
Braswell has not been released yet, but is not it related?
0 kudos
6 Respuestas
泰竹村
Principiante
2.077 Vistas
Hallo Ivan,
Thank you for the reply.
Specification Update of Atom E38xx series is below.
VLI 89 is applicable.
https://www.intel.com/content/www/us/en/embedded/products/bay-trail/atom-e3800-family-spec-update.html
Specification Update Addendum such as Celeron J1900 is below.
VLP 1 will be applicable.
https://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/Celeron-J1900-N2807-N2930-IoT-SU-Addendum.pdf
Apollo lake's Specification Update can be found below.
APL 46 is applicable.
https://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/pentium-celeron-n-series-j-series-datasheet-spec-update.pdf
I hope to find out more information.
Take7.
Empleados
2.077 Vistas
Hello Take7,
I'm sorry, so I'm not sure what other information you need to find out, was this information useful for you or you need anything else?
Ivan U.
泰竹村
Principiante
2.077 Vistas
Hallo Ivan,
These errata are the same errata as the eratta of Atom C2000.
There is a concern that it will suddenly stop moving like Atom C2000.
There was a release in BayTrail and ApolloLake series such as Atom E38xx series and Celeron J1900 series.
As a CPU, I guess Braswell between them has the same errata, is not there?
To what extent do these errata actually occur?
In Atom C2000 it was reported that it will stop moving if it operates for 18 months.
Take7.
Empleados
2.077 Vistas
Hello Take7,
Please let me further investigate for you, once I get an answer I will post it here.
Ivan U.
Empleados
2.077 Vistas
Hello Take7,
After further research for this specific processor which is OEM processor, you need to contact the OEM or a FAE to get further information.
Ivan U.
Responder
