16801 Discussions
Thermal Interface Reinstall?
I will be reinstalling my Sandy Bridge CPU onto my replacement (rev 3.0) motherboard. I will also be reinstalling the supplied heat-sink/fan.
Will I need to perform any additional steps regarding the Thermal Interface material to ensure optimum cooling?
i5-2500k + Asus P8P67 Pro rev 3.0
Adolfo_S_Intel2
Normally you do not need to do any extra step, but if you believe that there is not enough thermal interface material to reinstall the fan/heatsink, then I would suggest removing the old thermal interface material, and applying new thermal interface material to the top of the processor.
You can buy thermal interface material from:
http://www.intel.com/support/processors/sb/CS-030329.htm http://www.intel.com/support/processors/sb/CS-030329.htm
