16854 Discussions
Trouble installing Q9400
Hello I recieved a q9400 today however when I boot up, the monitor isn't detected.
The motherboard is asus-p5k-pl-am
Ive got two gigs of ram
and cit 650w psu
also a ati 4850x2
Any help?
My present cpu is a p4 3.0ghz
Try to update the bios of the board using the Pentium 4 cpu.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5KPL-AM&product=1
Then try the Q9400 CPU.
All the best,
Aryan.
I have done unfortunately. From other forums on the internet, a commen theme may be my memory. Any help?
My memory by brand/type is
A data: 1gig ddr2 533(4)
Kingston KVR may also be a 533 after a quick look on the net.
Any idea?
Since this is an Asus motherboard, i cannot advise on the specifications related to the boards, I am more an Intel Product Guy.
You will need to check the board specs and memory compatibility.
Try to see if without any memory module on the board what happens.
I mean only Power supply, motherboard + cpu Q9400.
Does the board issue any beeps?
All the best,
Aryan.
I apologise - I'm sure I posted here.
The situation was resolved eariler this afternoon. The Kingston RAM that I had was a higher frequency, so when I booted up with just that RAM in, it worked. I've currently ordered replacement RAM for the 1gig that I lost, and am considering cooling options such as the Spire Themax 2. Thank you for your help.
